Sponsored by: Real Truck
No Start on ‘04 E350 SD
Old Aug 3, 2021 | 06:44 PM
TritonTamer's Avatar
TritonTamer
4wd High
Hey y’all!
I’ve had this happen to me twice and I can’t quite figure out what’s going on.
Truck fired right up and we drove it across town to run errands. Shut it off for less than 5min, hopped back in and she wouldn’t start. No turnover, clicks, nothing.
I had my iPhone plugged into the second cigarette lighter both times this has happened.
Ran through all the fuses thinking I blew one somewhere but they were all fine. I was able to jumpstart it with some cables and got her home. Shut it off and tried to restart it on the spot…nothing.
I notice the instrument needles start shaking at random times and will stop when I put my foot on the brake.
Any ideas?
Here are a couple of videos:
Video of nothing happening when attempting to start:
https://m.bixel1.net/83erok
Instrument cluster making noise with the door open during startup attempt. Slight rattle of needles:
https://m.bixel1.net/o4e37i
Old Aug 4, 2021 | 01:56 AM
Evan_P's Avatar
Evan_P
Test the batteries. Jump it to get it running and test the alternator to make sure its charging.
Old Aug 4, 2021 | 09:09 AM
TritonTamer
4wd High
Thanks, I was able to jump it this morning to get it moved to the driveway. Leads me to believe the alternator is going bad. I don’t have a multimeter to properly test it.
If she is indeed bad, is it worthwhile to upgrade to a larger amperage version? If so, what’s the recommended upgrade?
Old Aug 4, 2021 | 11:04 AM
Djosbun's Avatar
Djosbun
Some aftermarket USB charging devices emit an electrical interference that can cause strange issues. If this problem ONLY exists with the USB charger plugged in, throw it in the garbage (especially if it's a non-brand name charger).
-- Dave
Old Aug 5, 2021 | 12:20 PM
TritonTamer
4wd High
-- Dave
Thanks - I threw the charger out and trying to troubleshoot the issue now. Battery test came back fine so I took the alternator off and had it tested at a local shop. Alternator is fine so I'm a bit stumped at what to try next. Any ideas?
Old Aug 5, 2021 | 07:35 PM
JoePa2's Avatar
JoePa2
If it always starts when you jump start it the only thing happening is the source of the starting voltage is different from your present battery - so it must be something connected to your current battery - I assume you have cleaned all the terminals - I suspect your battery - have you tested your battery when you can't start the truck with a load tester to see what condition it is in at that time
Old Aug 10, 2021 | 01:22 PM
TritonTamer
4wd High
Yep, cleaned the terminals and tested the battery. Everything checks out. The van has started up every time since I re-installed the alternator and I can't replicate the issue. I had a neighbor suggest it might be the starter...
Dogman_528
Nov 20, 2015 09:15 AM
chorepail
2004 - 2008 F150
Mar 11, 2014 08:55 AM
patrickke
Jun 25, 2009 07:55 AM
rstephenw
Jun 7, 2004 04:52 PM
