So I'm finally getting around to replace my missing battery tie down. Does anyone know if the stock (https://shop.broncograveyard.com/Bat...uctinfo/38015/) will fit a group size 65 battery? Otherwise i'm open to suggestions.
Can’t tell you if it will fit a group 65 battery. I do have one of those reproduction holddowns (from Dennis Carpenter) and it measures 6-5/16” inside, where it fits across the top of a battery.
pretty sure group 65 battery is almost 7.5" across.
The original hold downs fit perfectly over the original battery with little to spare, maybe a 1/16". Look up the dimensions of the original battery for your truck and compare that to the one you want to use.
