2019 SuperDuty pop
Old Aug 2, 2021 | 02:29 AM
Sprucestroke's Avatar
Sprucestroke
2019 SuperDuty pop
Was wondering if any of you have experienced a pop feel through the steering wheel going over bumps. almost as if something is loose.
Truck has 30k miles. ive owned it since day one. took it to ford for this and they put the upgraded steering stabilizer on it which i cant convince them it didnt help lol
I dont hear any sounds but just feel the pop/bouncing in the steering wheel.
Everything looks in place and seems tight
Old Aug 2, 2021 | 08:02 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Take it to a different dealer.
Old Aug 2, 2021 | 09:01 AM
Fishgetter's Avatar
Fishgetter
I experience similar feeling. My dealer did nothing. If I had to guess it’s the track bar but not positive.
Old Aug 3, 2021 | 08:59 PM
Aad2797's Avatar
Aad2797
Mine has been doing this. Feel it in the accelerator pedal also. More so while going slow and turning.
Old Aug 3, 2021 | 09:49 PM
Joe T's Avatar
Joe T
Check the balljoints too.
Old Aug 3, 2021 | 10:00 PM
Aad2797's Avatar
Aad2797
Done a lot of reading on this and seems the steering stabilizer was updated in 2020 and has fixed this issue on a few trucks. I had a friend under the hood pulling on the steering shaft while I was in the cab with my hands on the steering wheel and it’s the identical feeling that I notice while driving.
Old Aug 3, 2021 | 10:02 PM
CT_Hiker's Avatar
CT_Hiker
Trailering
Following this thread, as your description sounds close to how my '19 with 20k feels. I thought it was a very slight binding and then release feel in the steering wheel over minor bumps and dips, but pretty subtle. "Pop" seems right.
Have an aftermarket dual steering stabilizer on for the past 10k and that hasn't made any difference. No lift. Hope someone can determine the problem, as it just doesn't feel quite right.
Old Aug 3, 2021 | 10:15 PM
morehouse7's Avatar
morehouse7
Gotta go through all the front end parts on these trucks and look for play in the joints and loose connections. The quality control of some of the ball joints has been suspect where you see premature wear and out of tolerance right from the factory. When you find the issues replace with quality parts not OEM, you'll have better luck.
Old Aug 3, 2021 | 10:42 PM
StonedGrey's Avatar
StonedGrey
Sound just like a bad steering shaft like many people report. Its normally accompanied by a loose tapping feeling in the accelerator pedal. Ford service departments are too stupid to replicate it. At least that's what most people report Ford telling them.
Theres an entire thread on this somewhere.
I have the same tapping feeling in my f350.
Old Aug 3, 2021 | 11:40 PM
4wd6.7L's Avatar
4wd6.7L
This the one? https://www.ford-trucks.com/forums/1...ing-shaft.html
Old Aug 4, 2021 | 12:13 AM
StonedGrey's Avatar
StonedGrey
Thats the thread.
Old Aug 4, 2021 | 05:23 AM
Aad2797's Avatar
Aad2797
My 22 drw should be built on the 16th otherwise I would have replaced it by now
Old Aug 4, 2021 | 05:53 AM
GpGuy84's Avatar
GpGuy84
Yup. 19 F-250 4x4 30,500 miles. Same thing. But I feel it in the wheel and accelerator pedal...
llmflyfisher
May 8, 2025 08:45 PM
Ty.redbeard
Oct 26, 2022 10:05 AM
zrising400
Jul 1, 2016 09:16 PM
Sgt93
6.7L Power Stroke Diesel
49
Nov 5, 2010 10:19 AM
