Running threads with tap—Radius Arms
Old Aug 1, 2021 | 03:20 PM
ivsamhain's Avatar
ivsamhain
Ok so we know the bolt head is 13/16, my gauge says it is a 9/16 bolt and 9/16 bolt hole. And a Harbor Freight tap/die set 1/2 NC13 tap (thread chaser) threaded right in by hand. Of course I just removed the bolt yesterday. Best is to get it started straight and just clean out the threads, you do not want to start it crooked and cut NEW threads. Liberal amount of PB Blaster or WD to wash out the crud in side, before and while cleaning with the tap.
NC is None Course, meaning the thread. So do not use a fine course tap. Now I use the HF stuff when I am cleaning out threads, but it I was to have to cut good thread in that area and any other critical tapping needed, I would definitely use WAY higher QUALITY made tools.
that would be national coarse, as opposed to national fine. In this case 9/16-12, where fine would be 18 threads per inch.
Old Aug 1, 2021 | 04:06 PM
redroad's Avatar
redroad
It is important to use a "thread chaser" in this application as opposed to a traditional tap. If you don't know the reason why give this a read ..
Old Aug 1, 2021 | 04:54 PM
Truckerbase's Avatar
Truckerbase
Originally Posted by RKDxpress
You could go to the hardware store and get plumbers cleaning brush 1/2" and 3/4" for copper soldering.
Exactly. I used a .50 caliber rifle brush and pb blaster: worked good enough…
Old Aug 1, 2021 | 06:01 PM
redroad's Avatar
redroad
Well given the maximum effective range of a 50 cal. rifle is 2,000 meters I won't need my reading glasses for this job then.
Old Aug 1, 2021 | 06:08 PM
Truckerbase
Yeah, I was going to use a ghost sight to get the job done; then I remembered I’m old, too….
you and me both, brother….
Old Aug 1, 2021 | 10:40 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I guess making a terminology correction is sort of that same as helping in the 1st place....sort of. What the hell was I drinking when I said "none course" instead of national course. And then I go and say "tap (thread chaser)" like it is one of the same.
redroad nice link, thanks.
Old Aug 2, 2021 | 08:24 PM
ivsamhain's Avatar
ivsamhain
I suppose it is, sort of. As, if he goes looking for a none course tap online he will not be able to find one; and of course if he goes looking for one as opposed to a fine course tap in person, they may wonder if he’s having a stroke.
Old Aug 2, 2021 | 09:18 PM
77&79F250's Avatar
77&79F250
Well sounds like the OP got it handled with a .50 caliber rifle brush and pb blaster.
Old Aug 2, 2021 | 11:49 PM
Truckerbase
Yes. Passenger side is completely reassembled. Working on Driver side, now.
Nationally speaking, I’m sure it’ll be FINE…
; O )
Old Aug 3, 2021 | 06:51 AM
77&79F250's Avatar
77&79F250
Oh you got funny game now, glad to hear it is going back together for you.
NW 150
Offroad & 4x4
23
Apr 13, 2013 10:30 PM
1981F250
May 22, 2012 10:55 PM
3Mike6
Jun 23, 2007 10:56 PM
fred_79f250
Oct 14, 2005 09:47 PM
fred_79f250
Oct 5, 2005 05:07 PM
