Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Radiator
Old Jul 29, 2021 | 11:25 AM
Chip912's Avatar
Chip912
Radiator
Good day to all! I have a 1986 Ford F800 with a bucket and boom on it. I think it is an old retired CL+P truck. The radiator is totally restricted, so it over heats. I took the rad. out and had it boiled out. They boiled it 5 times to descale it enough to get enough flow through it. Problem is, now the core is weak, and has many leaks. A recore is too expensive($1k min) so I'm looking to see if there are any used rads out there. This unit is used on our Lion's club Fairgrounds for light maintenance.
Any help is appreciated
Old Jul 29, 2021 | 11:49 AM
ford390gashog's Avatar
ford390gashog
The radiators are very expensive used and most are in no better shape.
Old Aug 4, 2021 | 09:22 PM
donjamer's Avatar
donjamer
Moved to appropriate forum
Old Aug 4, 2021 | 10:20 PM
ctubutis's Avatar
ctubutis
I moved it into the Large Truck forum, we generally don't deal with anything larger than an F-350 in 80-86.
Old Aug 4, 2021 | 11:16 PM
85e150's Avatar
85e150
Big truck, big expense.
https://www.radiatorexpress.com/part...ator/f800/1986
Does the Lion' Club value the services provided by the truck?
Old Aug 5, 2021 | 10:22 AM
Chip912's Avatar
Chip912
We have two bucket trucks. A1986 tilt cab F800, and a 1991 F800. Both are used on the fairgrounds for out of reach overhead work. Yes, we do value the trucks, but because of their age, they require some expensive repairs. The '86 overheated because the radiator is blocked. I tried to have it boiled out, but the core is now too thin. I have to re-core or replace the radiator.
Old Aug 6, 2021 | 10:43 AM
Destroked 450's Avatar
Destroked 450
There's not such thing as a tilt cab F series, do you mean tilt hood?
If it is a tilt cab it would be a C series
The radiators in the F series trucks were used from 1980-1993, the radiator it used depended on what engine the truck had
The C series was pretty much unchanged for the 60's to the end of production in the 90's, again the radiator used was dependent on the engine the truck had
Although these trucks are getting some age on them there are a good number of them still in big truck salvage yards, but it takes phone calls or other manual searches to find them as very few big truck dismantlers advertise on the net
Old Aug 6, 2021 | 01:37 PM
Chip912's Avatar
Chip912
Thank you! I stand corrected. I thought it odd that both were designated "F" series. The '91 is definitely an F. (tilt hood). The '86 must be a C (tilt cab) This is the one I am looking for a rad, for.
Old Aug 7, 2021 | 03:20 PM
Destroked 450
There were a lot of those trucks built but product ended in 1990 so in the past 30 years salvage trucks have been picked over pretty good
The engine in the truck also determines what radiator is needed, if diesel it's probably a 3208 Cat, gas would be 429
Old Aug 8, 2021 | 02:45 PM
Chip912's Avatar
Chip912
I haven't been able to find any C model in my area at all. Mine has a 429 gas engine in it
Old Aug 8, 2021 | 03:06 PM
Destroked 450
Don’t know where you’re located but there’s one in Ga
I googled Ford C-800 radiator and half dozen came up, if one of the diesel radiators or older 391, 477, 534 radiators can be used you have a lot more options
Old Aug 9, 2021 | 10:28 AM
Chip912's Avatar
Chip912
I am in Ct. As lond as it has the side ear mounts, it will probably work
ididntdoit99
Feb 3, 2008 01:29 PM
seadoo
Jun 13, 2007 10:44 PM
SShank42
Aug 12, 2005 10:46 AM
pancake
23
May 20, 2003 02:30 AM
