Sensor ?
Old Jul 29, 2021 | 09:45 AM
Rancherojef's Avatar
Rancherojef
Sensor ?
Can anyone please help identify what this sensor is/does. It is in the back of the block on the passenger side. I am overhauling a 1991 F250 5.0, fuel injected, 4wd, single cab with automatic transmission. I pulled the motor to rebuild after #1 & #5 rod bearings spun on the way home from buying it. The part # in the connector is FS3B-14489-U. I cannot find that number anywhere, nor can a few parts stores. I cannot locate the original sensor and it may have been removed when it was in the shop getting milled.
Old Jul 29, 2021 | 09:47 AM
Conanski's Avatar
Conanski
That is the knock sensor
Old Jul 29, 2021 | 09:53 AM
Rancherojef
Thank you SO much. Hopefully still available from parts stores.
I really appreciate the info.
If unavailable can I run the motor without it?
Old Jul 29, 2021 | 10:22 AM
JPIECHOC50's Avatar
JPIECHOC50
They're available. I think they're around $40 bucks last I checked. I believe you can run with it unplugged, maybe with an engine light though, idk
jrgarrett
May 8, 2024 12:01 AM
crimson5liter
Apr 17, 2021 05:45 PM
mcali2
Apr 1, 2016 11:38 AM
cpettymore7777
Apr 20, 2011 07:32 AM
cdiddy
17
Dec 31, 2006 02:24 PM
