I need help with math
Old Jul 29, 2021 | 08:14 PM
James_Western_Canada's Avatar
Those signs they put up that show your MPH, in my experience, all read low, so don't take their readouts seriously.
I gave you the formula, all you have to do is plug in the numbers.....
Or, if math is that painful, here is an online calculator, but be forewarned, you still have to plug the numbers in
**for the last numeric value (transmission ratio), enter 1 for direct drive, or the decimal number if in overdrive
https://spicerparts.com/calculators/...rpm-calculator
Old Jul 29, 2021 | 08:19 PM
Thunderkiss1965's Avatar
Thunderkiss1965
Yes, James. I saw the formula you provided, just need to get to the bottom of this tank of gas, which I should be able to do by the time I get home tonight. LoL.
BTW, I have confirmed the 80 @ 70 with a couple of GPS speedos. Thanks again!
Old Jul 30, 2021 | 05:16 AM
User 71024's Avatar
User 71024
Most areas have a measured mile on the high way or a side road that the towns use to calibrate Taxi meters, ask your local weights and measures where it is and check your odometer against the measured mile.
simple math.
Old Jul 30, 2021 | 03:33 PM
charliemccraney's Avatar
charliemccraney
Basically what you are wanting to do is compare mpg with a ratio of 1:1 to the overdrive ratio. This is easy. After the trans swap is complete take a trip, only going into 4th gear, calculate mpg then take a trip with overdrive, calculate mpg, and that is your comparison. This eliminates any other variable, providing the most accurate comparison since it will be the exact same drivetrain.
Old Jul 30, 2021 | 07:45 PM
Thunderkiss1965
Charlie! You are a genius! That is exactly what I will do. All the other nonsense was hurting my brain.
Old Aug 16, 2021 | 08:09 PM
Thunderkiss1965
First tank full with the overdrive is looking like 10.5 MPG. My reciepts from the 4 speed blew out of the window so I'll have to make a run without using the OD.
gtex
Jul 28, 2018 01:04 PM
jgavac
29
Oct 10, 2013 07:56 PM
tjc transport
29
Jan 13, 2009 08:18 AM
Wizardvette
1997 - 2003 F150
Mar 3, 2005 01:40 PM
gtex
18
Dec 23, 2004 09:52 PM
