2016 f150 headlight issue
Old Jul 28, 2021 | 10:09 AM
blackepitaph's Avatar
blackepitaph
Driver's side low beam is out. Replaced bulb ( two different new bulbs )and still not working. Driver's side high beam works. Passenger side high and low beams work. I'm not an electronics guy so I'd value suggestions.... Thanks.
Old Jul 28, 2021 | 10:46 AM
CR172's Avatar
CR172
Check the wiring at the connector.
Old Jul 28, 2021 | 10:48 AM
blackepitaph
At the bulb? Sorry to sound silly....
Old Jul 28, 2021 | 12:52 PM
JKBrad's Avatar
JKBrad
Make sure every wire has a pin on the end and that he pin is snapped into the connector that attached to the plug on the bulb.
Old Feb 15, 2022 | 07:46 PM
Lupe001's Avatar
Lupe001
Did you find the problem I’ve been having the same problem and gots me crazy checking fuses and all and can’t figure out what it is…
Bleishear
Electrical Systems/Wiring
Oct 26, 2018 07:03 PM
highteckredneck
1997 - 2003 F150
May 19, 2010 01:55 PM
homer4.2
Dec 11, 2009 03:33 AM
lon371
1997 - 2003 F150
Jan 30, 2005 11:21 AM
PA F150 4X4
Jun 2, 2003 07:01 PM
