Temp and fuel gauge
@Pappys53 , looks like you could use some cleaning to make some good electrical contact, both on the ground and the signal wire. CRC 2-26 or similar contact cleaner as well as some scotchbrite to ensure good grounding through the bolt contact area and the spade terminal for the signal wire.
It seems you have wires in the correct locations, with the ground going to the screw on the outside and the signal wire going to the center terminal.
MercuryM100
09-07-2004 12:13 PM
