2022 Unscheduled Super Duty List
At the request of a few members, I created this spreadsheet of unscheduled trucks. This is not a tracker in the sense that it does not connect to any outside source for updates, it is just a list which includes user-submitted information and vehicle options. It will sort by Order Date, with the earliest orders at the top. Each user will be responsible for submitting their own information, and updating as necessary.
Spreadsheet Link
2022 UNSCHEDULED SUPER DUTY LIST
Submission Form Link
SUBMISSION FORM - 2022 UNSCHEDULED SUPER DUTY LIST
VERY IMPORTANT - When you submit your truck, you will use your ZIP code Plus the two letter Paint Code (in CAPS) for your truck. This essentially becomes your PIN number. If you get this PIN number wrong, then you won't be able to update your entry without creating a duplicate and then I'll have to remove the duplicate, so don't do that.
SO JUST TO REITERATE, Your PIN will look like this:
34135HX - That is my ZIP and the paint code (in CAPS) for Antimatter Blue. No spaces, 7 digits.
If you don't know your paint code, there is a table in the submission form. I added the paint code incase we have two people in the same ZIP code on the tracker. If we have two people with the same ZIP and the same color, we're screwed.
Canadians - use whatever you want for your PIN, but write it down because you'll need it to change/update your info, or confirm your scheduling.
NEW 8/20/21 - Form to submit your Questions / Comments / Suggestions and Change Requests : REQUEST / SUGGESTION / COMMENT FORM
If you make a mistake when you submit your order (like you put 2022 instead of 2021 for your order date), just re-submit the form. You will have to answer all the questions and select all your options again, but you probably don't have anything better to do. If, at a later date we add more vehicle options, you will need to re-submit your truck with those additional vehicle options selected for them to appear.
I'VE BEEN SCHEDULED!
Possibly the most important part of the list. Once you get that glorious phone call, text or e-mail from your dealer that your truck has been scheduled, PLEASE come back here and complete this simple form to update the list. This will allow the poor soles who haven't been scheduled to see what trims, packages and options are getting scheduled.
I'VE BEEN SCHEDULED - CONFIRMATION <--- Click for Form
NEW 9/22/21 - PERIODIC PURGE - It will become necessary to remove entries that are no longer being monitored
The Problem: Users who may have submitted their information months ago may not come back and notify us via the I'VE BEEN SCHEDULED - CONFIRMATION FORM that their truck is scheduled. This will lead to a build up of trucks which are actually scheduled, but do not show that on the spreadsheet.
The Solution: I will periodically purge the spreadsheet of anyone who had not "checked-in" and preserved their entry. I don't plan to do this often, perhaps every 30 - 60 days, but it is necessary for the continued functionality of the spreadsheet.
Here is how it works: Once your truck is on the spreadsheet, you will have a Green or Red box in the far left column. Red means that this entry will be purged in the next round. Green means that the entry will be preserved. All you need to do to preserve your entry is click complete this form below which only asks for your PIN Number (usually ZIP and Paint Code). There is also a link at the very top of the PRESERVED column in the spreadsheet. Once you submit the form linked to here or on the spreadsheet, your box will turn green, and your data will remain when the spreadsheet is purged again. After the purge, the column will reset to red, and the process will start again. There will be plenty of time to check-in, and I will post several notices in the thread letting you know when the purge will occur.
2022 UNSCHEDULED LIST - ENTRY PRESERVATION
_______________________________________________
REMEMBER TO GET THIS INFO FROM YOUR DEALER WHEN THEY CONTACT YOU: 1. VIN NUMBER, 2. ORDER NUMBER, 3. BUILD WEEK.
Then, of course, you can go join the 2022 Tracking Spreadsheet here:
2022 Auto Update SD Tracker
Spreadsheet Link
The following 4 users liked this post by Phoenixfla:
The following 3 users liked this post by KU4OJ:
The following users liked this post:
The following 2 users liked this post by RidgwaySD:
Sadly I think anything in your order that is not available will cause the scheduling to be delayed. Ford built a bunch of '21s they couldn't complete, the purgatory trucks, and the consensus is they are not likely to do that again. I think this means they will not schedule your build until all of the parts are available, even mud flaps... What would be nice is if they would let the consumer know and give them a choice if there is a hold especially for something minor. The beast is huge though and they can't seem to be that proactive. I would hope that a status of "clean unscheduled" means they anticipate having all of the parts when your turn comes but I think it is actually just generic terminology left over from the days when parts shortages were not a problem and you still stand a chance of getting bumped if a part is unavailable.
And it's lonely being 2WD.
The following 2 users liked this post by beardly:
I was kind of hoping my low end special would get me through sooner but the whole thing seems like a crap shoot so I am sticking with what I wanted...
Actually I think it is the opposite, about 25% of the trucks on the list are King Ranch or higher. That is a much higher percentage than those that are on the scheduled list.
Thank your sir for putting all this together. Much appreciated.
just submitted my form. I was a little surprised Lariat value and ultimate packages weren’t on the list to track. I just changed my order from value to ultimate partly because I heard more ultimates are getting pulled in for scheduling.
The following 2 users liked this post by Phoenixfla:
