Running like crap
Old Jul 25, 2021 | 10:40 PM
Thomas Warm's Avatar
Thomas Warm
Running like crap
Just changed the the spark plugs and alternator and was driving and it started running like crap and having a bad misfire and bogged down a minute down the road from my house anyone know what might be going on its an 86 5.0 efi 4x4 with a c6, also the battery just stopped holding a charge so i don't know if that had something to do with it
Old Jul 26, 2021 | 05:18 AM
Franklin2's Avatar
Franklin2
I would say the battery and charging system would be a good place to start. Fix the obvious things first.
Old Jul 26, 2021 | 11:44 AM
kr98664's Avatar
kr98664
Originally Posted by Thomas Warm
Just changed the the spark plugs and alternator…
also the battery just stopped holding a charge…
Where’s my 11 foot pole? Lots of layers to unwrap here.
First thought with a brand new problem immediately after other work? Something was inadvertently disturbed, such as a coil wire knocked loose or plug wires crossed. The other possibility is a new part bad from stock. So I’d suggest revisiting all recent work.
Re: The battery. Please define “just stopped holding a charge”. More details, please. Has the battery itself failed? Or is there an external fault draining it when parked?
Did you have to jumpstart the poor engine? I’m wondering if that was the case with a battery that “just stopped holding a charge”. And then you also mentioned having replaced the alternator. I take it you had some sort of charging problem. Have you verified the charging system is now good? Or did you just replace the most expensive part in the system and pray? Have you charged that poor battery? You can’t rely on the alternator to properly recharge a severely depleted battery.
If you’re still driving around with a dead charging system and a dead battery, that could explain the rough running, with insufficient voltage to run the ignition, fuel pump, and injectors.
Old Jul 26, 2021 | 06:29 PM
Thomas Warm
i replaced the alternator because the voltage regulator was stuck wide open and draining the battery and the spark plugs because it misfired on decel and it stopped misfiring and stopped dying and i guess the battery is expired cause soon as it stopped golding a charge it ran like crap, the battery was already pretty small fr the truck so im suprised it cranked an ran all these months
Old Jul 26, 2021 | 07:45 PM
kr98664's Avatar
kr98664
i guess the battery is expired cause soon as it stopped holding a charge it ran like crap, the battery was already pretty small for the truck…
Not trying to bust your butt, but you still haven’t explained how you determined the battery isn’t holding a charge. Are you sure the battery itself is at fault? Or maybe it’s still not getting a proper charge? Or there’s an external fault running it down overnight?
Do yourself a YUGE favor and charge that poor battery. That’s a very basic step before any electrical troubleshooting. If any question about the overall health of the battery, have it tested at an auto parts store. Don’t keep trying to drive with a suspect battery. Trying to charge a failed battery is like trying to inflate a balloon with a hole in it. The charging system can’t keep up trying to build pressure (voltage).
Old Aug 1, 2021 | 01:10 PM
Thomas Warm
Found the new alternator was charging a whopping 2 volts
Old Aug 1, 2021 | 01:49 PM
kr98664's Avatar
kr98664
Huh? I'm lost. Where did you measure "2 volts"?
Was this measured at the battery? That would indicate a SEVERELY discharged battery. I can't imagine anything electrical would work at such a low voltage.
Still not trying to bust your butt, but have you charged that poor battery yet? That is a very basic step for any electrical troubleshooting. For example, the alternator needs battery voltage available to energize its field coils. If adequate voltage is not available at the field, you may not get any output. You'd think a perfectly good alternator was bad.
I can't stress strongly enough the need for a fully charged battery before condemning any parts. If you don't have a charger, take the battery to a parts store. They will typically test it for free and charge it if needed. If any doubt on the overall health of the battery, replace it. Make sure the replacement is fully charged, too. New batteries often don't have a full charge at time of sale, so be sure to ask for it.
Old Aug 6, 2021 | 08:41 PM
Thomas Warm
yes i charged the battery and it is now fine and happy
68shortbedmo
Jun 20, 2012 08:29 PM
99f350sd
Sep 30, 2009 08:54 PM
Primered 1966 f100
23
Jan 16, 2008 02:08 PM
36tbird
Jan 6, 2004 12:32 PM
Fifty4F100
May 13, 2003 08:42 AM
