A/C Controller Vacuum Line Question
Old Jul 25, 2021 | 10:23 PM
Aaron296's Avatar
Aaron296
Does anyone know what colored lines do what on the back of the A/C Controller? On a 1981 F-150 with factory A/C
All i have determined is black and white is the vac from motor
Old Jul 26, 2021 | 05:21 AM
Franklin2's Avatar
Franklin2
Here are the colored lines.
Old Jul 26, 2021 | 07:51 AM
Aaron296's Avatar
Aaron296
Thanks, I just got all that together. do you know where I could get new vents. I only had air coming out the far passenger side vent and turns out there is a rat nest in the vent system. The vents are breaking when removing them. i may need new ones if not I'm bout to break out the super glue
Old Jul 26, 2021 | 05:56 PM
FuzzFace2's Avatar
FuzzFace2
Dave thinks for that as I need to go back over my system to find if all is ok and why when on MAX AC pulling hills it goes to defrost.
I do have a new vacuum check valve but may also need a larger vacuum tank?
Aaron,
If someone can get the part numbers you might be able to find new ones but I would thing use is the only way to go here.
Any factory AC 80 - 86 truck (100 / 150 / 250 / 350) should work.
I dont know if the 87 - 90's would work as the dash has a different shape.
As for fixing what you have I dont think SG will cut it as I dont think it will stick to the duct plastic.
I would get https://www.plastex.net/ as it is made to fix plastic. I have used it and the repair was stronger than the part when the part fell out of my hands and had to fix it again.
Or I would get a plastic welder kit. https://go.harborfreight.com/?s=plas...Submit+search=
I dont have a plastic welder .... yet but would be nice to have one when needed for other projects.
Dave ----
Old Jul 27, 2021 | 12:16 AM
Aaron296's Avatar
Aaron296
Thanks for reminding me that I have a plastic welder, I picked it up from harbor freight a while ago. it around here somewhere
Old Jul 27, 2021 | 05:43 AM
FuzzFace2's Avatar
FuzzFace2
Glad I could help
Dave. ----
masonp
Jul 21, 2016 07:57 AM
1979 300i6
Jan 12, 2014 07:05 PM
murph1
1997 - 2003 F150
Nov 6, 2008 10:18 AM
mpavlyik
Bronco II
Sep 23, 2003 01:15 PM
