The truck is a 1983 F250 2wd with a 300 Inline six, that I recently bought and have had a fair amount of problems stemming to ham handed mechanics at the previous shop (it was a county rig). So I sheared the teeth of the fiber cam gear and decided to pull the motor and reseal the greasy beast, and in the process of replacing valve stem seals. I noticed the rocker arm studs are completely worn down, my guess from over torqueing, and are 100% needing to be replaced. This is not a performance rig, just a Daily Driver for me, so I want to do it right but keep the cost low. Ive never messed with rockers much and am almost clueless about non adjustable rockers, and backlash etc.
What can I replace the studs with? (they are pressed in)
What can I replace the rockers with? do they need to be replaced?
The fulcrum washers?? are suspect and most likely shot too, what can I replace them with?
What is my cost likely to be for a machinist to do the work? (the head is out and cleaned!)
You will have to pull those out and replace with new press-in studs. Or take the head to a machine shop,, they will pull the studs, machine down the bosses, and tap the holes. Then you can use screw in studs. Whatever you do , make sure to put sealer on it, those holes are open to the coolant passages.
If they are worn, they need replaced. You can replace them with stock rockers, or if you converted to screw in studs you may have different options.
The washers wear with the rockers. Replace them if they need it.
Prices vary by areas of the country. But generally speaking, labor rates are high. Machine shops are closing, so unless you live in a larger city you may have a hard time finding someone or the ones you do find are backed up. You may also check out the local autoparts stores, they sell remanufactured heads usually, and you turn in your core.
Thanks Dave!
Couple quick questions:
I could not find new press in studs, are they still available say online?
I like the idea of threaded studs, how do I find a set that are the right height to reuse the old rockers?
What are my options for new rockers, if I opt for the threaded studs?
I know a lot of chevy guys are using a kit from comp cams to pull and thread the studs in themselves, is this doable if a short enough stud can be found?
I'm a geologist and a rancher on the side, or by moonlight to be more accurate, not a machinist or mechanic.
Your best bet is to find the machinist you like and that can help you. They can get the parts, and have the experience to help you get it going again. They have their preferences on what to use because they will guarantee their work. If you get hem hawing and the run around, then you know to move on and find someone else. They will want to look at the head and all your parts, and they can determine right away what it's going to need to make it last. I am assuming the least you are going to want to do is get the valves reground. So if you take it to them for that, they will have an opinion on the rest of it also.
I had two press in studs redone. Here in Houston I paid about 90 bucks supplying the studs. I could have gone the screw ins route, but I am not hard on the old gal, so I minimized my final cost. I think I have a couple NOS left over (it was a pack of four). The weren't much , so if you need them, I'll let them go for shipping and a six of Lone Star.
