Alternator Wiring Mess
In the fist picture below, you'll see the black wire which connects to the top bolt on my alternator. This wire is split into three wires, 2 yellow and 1 black. Both the yellow wires connect to the plug in the second picture, which hooks into the harness that runs into the passenger side firewall. The black wire that splits off the main alternator wire, is split further into two wires, 1 red which connects to the same plug below, and 1 larger gauge red which connects to the starter solenoid.
As you can see, the plug is in need of replacement, and has corrosion on the firewall side of the connection.
I haven't seen plugs like this at the store, I think the guy at Napa said they don't make them anymore. Can I just cut the plug out, and replace all the wiring between the plug and the alternator, splitting and splicing things the same way it is done now?
I changed the trucks harness using my parts truck one and then had to match up wires.
I also had to make a adapter / jumper as my harness had a different plug than the ALT I was going to use.
Dave ----
Dave ----
Use a ratcheting wire crimper and cover all of the connectors with heat shrink. Here's an intro wire crimper kit:
You can even get heat shrink at Horrible Freight:
https://www.harborfreight.com/120-pi...set-67530.html
The parts truck harness I used had a different plug to hook to the ALT, parts truck did not have a ALT.
Because I am cheap and the ALT worked and not wanting to cut a good harnes I made 2 jumper wires to fit the harness plug and the ALT.
Dave. ----
https://www.amazon.com/Terminals-Qib...7401286&sr=8-5
Normally there is not one used, the wires from the regulator match the ALT and either plug in or screw on / push on.
That white plug to the right is the harness from the regulator / truck side.
You can see what my ALT connections look like.
No way they would work with out cutting & splicing ends on the trucks harness (that was not going to happen) or swap out a good working ALT (again not going to happen).
So my fix was to make 2 short wires to fit in the white plug with ends to fit where needed on the ALT.
What you dont see in the picture is the 10 ga. black / orange wire that goes from the ALT output to the battery that is part of the trucks harness.
Later if the ALT dose fail I will get the right one so I can remove the 2 "adapter wires" so the white plug will plug into the ALT.
Or depending how I feel upgrade to a 3G ALT but I dont see the need for it on my truck as I am not running anything needing the extra power out put from the ALT.
Dave ----
That is a smaller harness that goes between the trucks main harness and the ALT.
I dont know what the ALT end of that harness looks like on your truck but if it is different than mine that is how FORD switched the wiring, they just pull the needed ALT harness from the bin to match the ALT.
I guess I could try and find that harness that would fit the ALT I have but the setup I have is working so I cant see me changing it out.
Now if you a junk yard with trucks in it you can see if they have a ALT harness that will fit your ALT and swap them around.
Dave ----
S202 is the big ugly splice that was wrapped in tape from the factory. That's exactly how my '84 looked.
S203 is near the starter relay, at the end of fusible link J. It has one big wire (the shunt) and two smaller wires.
Connector C610 is the big round one in your picture. It has one heavy wire and three smaller wires. Note how it is not shown in one location in the diagram, but kinda scattered across the page. See to the right of S202, at both sides of the ammeter, and to the lower right of the alternator.
While you're in there, have you considered converting from a voltmeter to an ammeter? I did the Rocketman conversion a couple of years ago and highly recommend it:
https://www.ford-trucks.com/forums/1...olt-meter.html
An ammeter is kind of useless for consistent monitoring of the electrical system. It would be easy to miss a slow discharge, such as if the charging system wasn't fully up to snuff. A voltmeter is much more useful, in my over-rated opinion, for catching a charging system fault before it leaves you stranded. I have a diagram of how I rewired my truck for a voltmeter, and eliminated the shunt and C610 in the process. It's on my other computer but I can post it tomorrow if interested.
The ammeter, if that is the actual meter in the dash, doesn't work, so I may come back to this.
