Steering column for automatic 1970 Ford pickup
I'm kind of new to fixing trucks, so bear with my newbie-ness
I am in need of a new steering column for my 1970 Ford pickup 2wd with power steering. It's an automatic, and its gear selector has P, R, D, 1 and 2. I'm sorry I don't know the proper terminology for this! It's also a Camper Special, in case that matters.
I've checked the Marketplace here, as well as eBay, and am Googling around, but I'm wondering if there's something in particular I should be looking out for? My friend is planning to put it in (my linkage is totally worn out), but I'm worried I'm going to buy the wrong thing
Any advice would be so appreciated!
Thank you-
Susan
https://www.ford-trucks.com/forums/1...l#post16156524
Thanks so much for your reply. I don't know where it is worn out, exactly– I'd have to ask my friend, who is working on it for me. But he is a mechanic who has been working on these Fords since he was a kid, and it seems like he tried just about everything before reluctantly admitting that it needed a new steering column... I will mention the bushing idea to him, just in case, though. Thank you!
So, this would be considered an F-250? It doesn't say that anywhere on the truck, but I definitely think it's bigger than a 150. I do feel like I was told the engine was over 400ccs when i bought it. Should probably know that.
Any thoughts on where you'd find a new steering column, if you needed one? Thanks again!
S
To my knowledge, F100 vs F250, the columns are the same. Not sure about F350 but I believe they are too. 4wd steering setup is different than 2wd, but I *think* the columns themselves are still the same.
I don’t believe anyone reproduces exact replacement columns (most aftermarket are GM based), but there is a fellow in Alabama I believe who rebuilds our columns. Depending on how big a hurry you are in, you could probably ship him yours and have it redone, so you’d still have the original column when you are done. I could probably find his contact info if you are interested. I’ve never used him but he has a good reputation on the F100 Facebook groups I’m on.
