Dummy plug replacement
Old Jul 24, 2021 | 04:28 AM
2005x6.0's Avatar
2005x6.0
Gonna be tackling my dummy plugs and stand pipes today.just wondering if any of you guys know how long it might take.
Old Jul 24, 2021 | 07:28 AM
Visurveyor's Avatar
Visurveyor
With the Wright tools, couple hours. The back and lower side valve cover bolts on the passenger side are a bi---. A good adjustable angle wrachet wrench will save you a lot of time. Good luck.
Old Jul 24, 2021 | 07:46 AM
craftsmangary's Avatar
craftsmangary
Take the right side fender liner out, then you can take the inside panel of the heat box off that'll open that area right up, I can do all that in about 15 minutes.
Old Jul 24, 2021 | 08:11 AM
Visurveyor's Avatar
Visurveyor
That would be easier, if you don't have a flare package on. Removing the flare and reinstalling with out damage is time consuming.
You can reach in with a wrachet wrench and get those 3 bolts without all the fender well aggravation.
Old Jul 24, 2021 | 09:05 AM
IHateCommieCars's Avatar
IHateCommieCars
I've never removed the wheel liner and heater box before. Maybe worth the effort, but I expect, like most of these projects, the first time you remove/replace those parts takes a whole lot longer than the next times. Most people jump into the valve covers thinking they're not going to be coming back for awhile and don't bother learning such time-saving tricks because they won't actually save time the first time.
That said, if you haven't done dummy plugs and standpipes before, a lot of time will be spent digging through your tools looking for the exact combination of drivers, sockets, extensions required for each of quite a few hard-to-reach, PITA bolts/nuts. The next time you do the valve covers and oil rail will be a lot easier.
Blow/vacuum it all off good before you open the covers, be careful with your nipple cups and drizzle some oil in the tops of those injectors going back together. It would take my old self using hand tools a lot longer than the speed techs, maybe 4 hours for both sides,
Old Jul 24, 2021 | 09:46 AM
2005x6.0's Avatar
2005x6.0
Thanks for the replies guys .just watched diesel tech Ron's video. Doesn't look to bad
Tofan
Jan 2, 2017 08:52 PM
jspringator
Modular V10 (6.8l)
Oct 19, 2013 08:50 AM
kawa
22
Sep 17, 2010 03:06 PM
gulf pilot
Jun 5, 2008 03:48 PM
duane reed
1983 - 2012 Ranger & B-Series
Dec 29, 2003 05:50 PM
