Hesitation and stalling?
Old Jul 22, 2021 | 09:23 PM
bidderbl's Avatar
bidderbl
So trying to figure out my problem on my 2015 ford f150. When I drive for a while and then come to a stop it hesitates or sputters sometimes. Not every time but every once in a while it stalls out. Starts right back up. Had all the plugs changed and spent a grand at ford dealership to fix it. But still happens. I figure it may be fuel injectors but had those all cleaned up also. Plugs are firing. Spaced correctly. Just don't know what to do and looking for some help from those way more knowledgeable than I. Thanks,
-MAS
Old Jul 22, 2021 | 11:14 PM
JKBrad's Avatar
JKBrad
What engine do you have?
Check the ground cable and connection on your battery. A bad ground can cause a lot of weird issues. Same with a corroded ground cable.
Old Jul 23, 2021 | 07:03 AM
SpencerPJ's Avatar
SpencerPJ
What engine? Seems I read and hear of quirky things when the throttle body gets dirty. Seems many just replace it.
Old Jul 23, 2021 | 07:06 AM
ford390gashog's Avatar
ford390gashog
Replace the throttle body, these are a replaceable maintenance item. Don't attempt to clean or the stepper motor will be damaged.
Old Jul 23, 2021 | 07:23 AM
bidderbl's Avatar
bidderbl
Yep. Had that replaced a month ago. Sorry. Forgot to mention that
Old Jul 23, 2021 | 11:47 AM
kehinnc's Avatar
kehinnc
How often should the TB be replaced?
Old Jul 23, 2021 | 12:16 PM
ford390gashog
Normally 150k is the lifespan however I have seen them at 200k without issues.
Old Jul 24, 2021 | 09:44 AM
bidderbl's Avatar
bidderbl
What about the vvt? Could that be the culprit? If you think it is where is it located on a 5.0 V8
daltonjamesadams
Jan 31, 2018 06:32 PM
Ted928
2004 - 2008 F150
15
Sep 7, 2010 04:55 PM
is300wrx
2004 - 2008 F150
25
Sep 18, 2006 12:13 PM
tealboy1
1997 - 2003 F150
Oct 14, 2004 08:42 AM
Snatch Block
Aug 27, 2003 06:13 AM
