Weird Fuel Pump Problems 302 EFI
Old Jul 22, 2021 | 02:57 PM
jacob10miller's Avatar
jacob10miller
This is the second fuel pump i have installed and it's still acting the same, electric hanger assembly fuel pump, when I prime the pump i can hear it run but little to no pressure is coming out, same thing happened to my last fuel pump. This truck had been sitting for about 6 to 7 years and was running when i went to look at it on bad gas. I assumed the fuel pump went out and it looked shot when I took it out. I disconnected the fuel line to the tank selector valve and primed the pump but it was just barely dripping out gas. And no the line is not clogged because I just replaced it. I do not think this is a electrical issue unless it's stuck on the rear tank but i doubt it because I can hear the front one running, which is the one I replaced. I can run the fuel pump using a jump wire to constantly run the fuel pump and it sounds normal but it just barely drips out gas like before. I am completely stumped on this one and I would greatly appreciate some help, thanks.
Old Jul 23, 2021 | 07:11 AM
Olds64's Avatar
Olds64
If you're sure the fuel line isn't clogged then the only other parts in the system are the fuel pump and tank selector valve. Remove the selector valve from the system and run the fuel line directly from the tank, to the pump and up to the engine. If it still dribbles you know the pump is bad or the fuel line is clogged. Good luck.
Old Jul 23, 2021 | 09:08 AM
jacob10miller
2nd fuel pump
This is the second fuel pump I've had and its doing the same thing, i disconnected the line to the tank selector and it just dribbles out.
Old Jul 23, 2021 | 01:06 PM
FuzzFace2's Avatar
FuzzFace2
So you have a line right off the pump nothing else between tank and hose end and it drips out?
What if the pump was wire backwards?
Try jumping the 2 wires to the pump switched and see what happens.
Dave. ----
Old Jul 23, 2021 | 04:14 PM
Max Capacity's Avatar
Max Capacity
FWIW, I replaced the fuel filter under the cab on the frame. It was dirty enough to cause the engine to starve for fuel when I tried to go faster.
NAPA has a filter element for $10.00 or so.
Old Jul 23, 2021 | 04:44 PM
jacob10miller
Replaced fuel pump relay now it wont click?
The pump no longer primes after I replaced relay with the old and new relay.
Old Jul 23, 2021 | 05:14 PM
jacob10miller
Nvm got relay to run again and switched 2 wires on fuel pump but now it wont run at all so the wires are right, the fuel pump is running but giving out very little pressure, this is the second brand new fuel pump to do this.
Old Jul 23, 2021 | 05:27 PM
jacob10miller
Now fuel pump isn't getting power at all but i can hear the relay click
Old Jul 23, 2021 | 06:01 PM
jacob10miller
Ok my fuel pump has power again after i messed with the starter solenoid, there are a couple things on it but the fuel pump is still dribbling.
Old Jul 23, 2021 | 06:04 PM
jacob10miller
These are on the starter solenoid on the positive side
Old Jul 24, 2021 | 06:45 AM
FuzzFace2's Avatar
FuzzFace2
2 look to be fuse links and that add on end could have been a fuse link also that went bad and was replaced with a normal wire.
They all look dirty, clean them with sand paper to look all shiny and see if that helps.
A bad / weak connection could make the pump run slow.
The other thing I would do as a test is bypass the relay and put a battery volts to the wire going to the pump from the relay and see what happens.
Or run a wire from the battery to the pump would be even better just make sure the pump has a ground if you do it this way.
Dave ----
jacob10miller
17
Jul 18, 2021 11:13 PM
biggymrat
Apr 13, 2011 09:43 PM
kenworthfan
May 29, 2008 11:49 PM
olddawg
Jun 23, 2002 09:18 PM
