T-case Floor Cutout
Old Jul 21, 2021 | 09:47 AM
SVandal's Avatar
SVandal
T-case Floor Cutout
Is the cutout for the T-case shifter in all cabs or only just the 4x4 models? I want to convert over to 4x4 and wondering if I will need to do some cutting on the body.
Old Jul 21, 2021 | 10:05 AM
My4Fordtrucks's Avatar
My4Fordtrucks
No. It is not in all cabs. I am not sure if the transmission made a difference meaning if you had a manual transmission there would be a hole for the transfer case because of the different tunnel cover.
Old Jul 21, 2021 | 10:10 AM
SVandal's Avatar
SVandal
Ok. Mine is an automatic. Sounds like I will have to cut some sheet metal to make it work if I go that route vs an electric shift t-case.
Old Jul 21, 2021 | 10:45 AM
GoinBoarding's Avatar
GoinBoarding
My '96 had no cutout for trans or t-case. Came as an electric t-case 4x4 with E4OD. There's a stamped outline though, so pretty straightforward to figure out.
Old Jul 21, 2021 | 12:18 PM
GNR22's Avatar
GNR22
We just cut out the floor on a '94 2 wheel drive cab yesterday for this. You can distinctly see the outline where the shifter hole should be for the t-case. We cut it out with a plasma cutter.
Old Jul 21, 2021 | 01:08 PM
SVandal's Avatar
SVandal
Thank you for the information. Sounds very doable. Now I just need some hardware from a donor.
Old Jul 21, 2021 | 09:31 PM
IBLDBLUE's Avatar
IBLDBLUE
My 1990 2wd had the cut out. There was a plate being held in with 4 screws and some silicon.
Old May 6, 2023 | 03:16 PM
bulletpruf's Avatar
bulletpruf
No cutout on my 1987 F350, ZF5. Any ideas on where to cut? Thanks
Old May 6, 2023 | 06:06 PM
My4Fordtrucks
What transfer case shifter are you using? On my ‘87 Bronco the transfer case shifter is centered on the top of the cover.
Old May 6, 2023 | 09:06 PM
bulletpruf's Avatar
bulletpruf
Here's a pic of where the hole is; posted on oilburners. Waiting for him to send some dimensions.
Old May 8, 2023 | 06:04 AM
SVandal's Avatar
SVandal
Is that for an 87? I’ve seen earlier trucks had the Tcase shifter in the tunnel cover.
pictures here are for a 96
Old May 8, 2023 | 10:17 AM
bulletpruf's Avatar
bulletpruf
Yes, it's for an '87. Transfer case shifter is in the same spot as the pics you posted. Thanks
Old May 8, 2023 | 11:42 AM
My4Fordtrucks
That’s why I asked what shifter is being used. This is where my ‘87 Bronco transfer case shift is located.
Old May 8, 2023 | 12:03 PM
bulletpruf's Avatar
bulletpruf
no room for it there; that’s where my ZF5 shifter is
Old May 8, 2023 | 03:09 PM
My4Fordtrucks
Picture of an ‘87 with manual transmission. Transfer case shifter is still on top of the hump.
