Tire cupping
Old Jul 18, 2021 | 03:15 PM
Ees73's Avatar
Ees73
Tire cupping
2020 f350 dually 12000 miles tires cupping bad will bring to dealer anyone else see this? First dually by new truck every max 3 years never seen on single rear wheel trucks?? Running Toyo CT's stock size
Old Jul 18, 2021 | 03:55 PM
Crotchety Ford truck only's Avatar
I thought cupping was due to out of balance
Old Jul 18, 2021 | 03:59 PM
RidgwaySD's Avatar
RidgwaySD
Have you rotated the tires? I would have rotated twice by 12,000 miles It makes a big difference. There is a lot of weight on those relatively narrow tires.
Old Jul 18, 2021 | 04:02 PM
SARDiverDan's Avatar
SARDiverDan
Could be balance issues, alignment issues, or suspension issues. Need to check all three to figure out the problem. I try and rotate every 3-5 thousand miles.
Old Jul 18, 2021 | 05:01 PM
George C's Avatar
George C
I’m my experience, cupping is due to poor shocks.
Old Jul 18, 2021 | 05:16 PM
Ding126's Avatar
Ding126
Get a new pair of shocks and a alignment. Im sure that will correct your issues.
Manufacture alignment tolerances are " with in " and OE shocks suck, poor quality. New shocks and an alignment should be the first thing all buyers should so
Old Jul 18, 2021 | 11:35 PM
Desert Moto's Avatar
Desert Moto
If you tow frequently, that will exaggerate all of the above issues. Towing will sometimes cause porposing and create the illusion of bad shocks and could cause the cupping.
Old Jul 20, 2021 | 02:48 PM
Miles Mac's Avatar
Miles Mac
I have a set of these balancers on my F450, they are fantastic. removed the wheel weights on the outer aluminum wheels and it drives smooth as silk.
https://www.centramatic.com/
Old Jul 20, 2021 | 03:06 PM
PunksSuperDuty's Avatar
PunksSuperDuty
Miles Mac did you also remove any weights from the inner rear duals as well? Its my understanding the centramatics will balance the entire wheel/tire/hub assembly. How is the noise level with the centramatics at low speeds? thanks!
Old Jul 20, 2021 | 03:17 PM
Big Mak's Avatar
Big Mak
My tires in my old F350 cupped because I had poor shocks and I did not rotate them. Only 20k miles, tires were TOAST.
Old Jul 20, 2021 | 09:51 PM
Lamoon78's Avatar
Lamoon78
All I do is rotate the fronts and the outer duals every 5,000 then at 15,000 I will have them all derimed and swapped.
Old Jul 21, 2021 | 06:00 AM
Miles Mac's Avatar
Miles Mac
I left the weights on the inner rear for now, my concern was corrosion on the aluminum rims, going forward w/ new tires I wont balance anything prior to installation. Other than a slight "wooshing" sound if you stand next to the tires, I don't hear anything from the cab.
Old Jul 27, 2021 | 08:11 AM
Lin19687's Avatar
Lin19687
Veteran: Navy
What tires are they ?
I have stock Conti's and had outer wear by 2k and cupping st 4k. They warrantied the tires and supposedly did a road force balance.
NOT a dually and this is on the fronts
Old Jul 27, 2021 | 09:50 AM
Ees73's Avatar
Ees73
thanks for all the info my really is checking it out but i did notice now that i think of it a bounce in front at times when i changed to dually. so i have aired up to full 80 psi in front and that has gone away now i will put those tires in back. In meantime my dealer is great for taking care of me, so will see what they come up with. Apparently Talking with a trucker friend they're front steer tires have same issues even if low on pressure 5 10 lbs.
Old Jul 27, 2021 | 10:39 AM
Beast2.0's Avatar
Beast2.0
Agreed!! I replaced my shocks w/Bilstein 4600 and with rotations, I have 38k on my original Michelin's. Hoping to get 45K+ out of them
