Tire cupping
Thought I'd update cupping started again I have now gone to bilsteins I take stock ford shocks compress takes forever to return bilsteins is like instant. Can't believe the difference and that ford has such cheap shocks. New truck next year will go straight to bilsteins. Good advise thanks
Originally Posted by Miles Mac;[url=tel:19980038
19980038[/url]]I have a set of these balancers on my F450, they are fantastic. removed the wheel weights on the outer aluminum wheels and it drives smooth as silk.
https://www.centramatic.com/
For those that rotate often, do you do it yourself? And if so, how do you reprogram the TPMS?
I have only experienced tire cupping on my other truck (not a SD). Aignment had been done but the tires that cupped did have issues with balancing. That same truck has 60k miles on the current set of tires without any cupping. Suspension was untouched. One shop said it could be caused by a few different things but that once it happens to the tire it doesn't go away.
X21bravo
6.7L Power Stroke Diesel
Feb 25, 2015 10:09 PM
PEI
Jul 24, 2010 05:34 AM
carlsson
Apr 27, 2008 05:55 PM
