looking for some info
Old Jul 17, 2021 | 07:48 AM
6-Ft-Under's Avatar
6-Ft-Under
I just purchased a 1963 Ford F100 with a inline six 3 spd in floor step side.
Truck is in decent shape and i picked it up for 1200.
Sorry no pictures yet as i am waiting on delivery.
motor not locked up i did check.
1 is how can i tell which engine it is as it is not original. Inline 6 with bolts going down threw valve cover lip and a weird looking fuel pump with a thread on can. intake and exhaust are on passenger side If that helps.
2 is this a 6 volt or 12 volt system so i can get proper battery.
3 how hard to put power brakes and power steering on this.
I cant wait till it gets here to start all the checks . i wanted something my wife and i could cruise to shows in and i finally found it.
does not look as though it will need alot to be road ready.
Thanks for any help Jeff Mc
Old Jul 17, 2021 | 10:34 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Sounds like you may have either a 240 or 300 inline 6 as a best guess. Pictures would help ID further and there are likely some casting numbers on the engine block that can help ID it.
All of our trucks used a 12 volt negative ground system
Power brakes are achieved by using a vacuum booster. Do you want to stay with the stock drum/drum brakes front and rear or upgrade those to disc at the same time. For a drum/drum system the single diaphragm boosters are a better choice while any others are best with a dual diaphragm. Type of booster and master if changing to a disc/drum system is important.
Power steering is a bit more complicated. The original Gemmer steering shaft extends into the gear box and has an external housing that the shaft is encompassed in. Electric power steering might be a simpler way to go than trying to find a new steering gear, column, pump with brackets and hoses, extra pulley groove to run the pump, etc.
Old Jul 17, 2021 | 10:16 PM
stephen.osborne1's Avatar
stephen.osborne1
Not that you asked, but you have a "flare side," not a step side...
TBHHUNT
19
Jul 19, 2012 11:25 PM
Slushdog21
Nov 14, 2010 12:03 AM
OleRed04
27
Sep 10, 2007 03:50 PM
sierraben
17
Jan 2, 2007 10:09 AM
Toyvo
General Automotive Discussion
May 16, 2004 08:47 PM
