Sponsored by: Real Truck
Amsoil
Old Jul 15, 2021 | 10:19 PM
Mountainman77's Avatar
Mountainman77
Amsoil
So here I am again trying to get some input. Does any one use the amsoil in their diesel. If you do which one and why. I’m thinking about is it worth spending the money on it. I own a 2015 superduty with just 135,000 miles on it. Let me know
Old Jul 16, 2021 | 08:21 AM
CP Dubbs's Avatar
CP Dubbs
Nope. Many other oils reasonably priced that give great results. Zero reason to use Amsoil.
Old Jul 16, 2021 | 08:27 AM
Akley88's Avatar
Akley88
i have never seen a need to spend that much for amsoil when im changing oil every 5k miles. I usually use Mobil 1 synthetic which i can get for 23 bucks for a 5 quart bottle.
Old Jul 16, 2021 | 08:35 AM
99powerstrokedF250's Avatar
99powerstrokedF250
If you are referring to the fuel additive, no, I never used it. There are other products that go a lot further and work just as well.
If you're referring to engine oil, yes, I used it, and it DID help with stiction in the injectors WHEN I WAS USING NON-SYNTHETIC OIL. Switching to Rotella T-6 full synthetic accomplished the same end goal for a bit less $$.
Old Jul 16, 2021 | 08:44 PM
Mountainman77
Well thanks my diesel people. I like hearing from real people that do real things with their truck. Always good to get some honest feed back.
Old Jul 16, 2021 | 09:31 PM
Fefanatic's Avatar
Fefanatic
I think you will find that stiction is more of a issue with 6.0 motors than it is with 6.7 so that shouldn't be a issue for you. FWIW, I used to sell Amsoil and I will attest that it is a great product but I don't use it in my '15 6.7. I stuck with Rotella T6 and it serves me and my engine well. I can't see any appreciable gain with Amsoil.
Old Jul 17, 2021 | 01:05 PM
MAJICDAN's Avatar
MAJICDAN
amsoil
I have been using Amsoil in my 6.0 diesel truck and my boat for over the last ten years with good results.
My boat is a motorsailer that we use to travel 5000 to 6000 miles a year. Perkins says to change the oil at 200 hours. I change the filter but not the oil every 200 hours.
I use the Amsoil heavy-duty marine 20-50 synthetic oil. that is rated for 800 hours. I changed it at 800 hours and I sent in a sample to a lab. The oil was still fine to go.at 800 hours.
My 2005 Ford 6.0 F350 dually has an F450 rear end with 4.30 rear gears
Amsoil rates the marine 20-50 oil for 25,000 miles. I have used it since breaking. After 20,000 miles the lab said that the oil was good to use.
I have changed my oil filter every 10,000 miles and the oil every 20,000 miles.
I had considered Mobile 1 buy Amsoil has better ratings for HD use and protection of seals.
I read that Amsoil did a test in an over the road semi for 50,000 miles without changing the oil.
The motor was torn down and rated as good as from the factory tollerances.
Old Jul 17, 2021 | 04:46 PM
Bigger Hammer's Avatar
Bigger Hammer
Another Amsoil user here, I use Amsoil HD Diesel & Marine 15W40 in our 6.0 Ex. Just had the heads removed and replaced at 150K miles, and the shop owner who I've known for a long time wanted to know what oil I was using. Everything inside/oil-lubricated looked perfect, honing on the cylinder walls still visible.
Also use the Marine 10W40 Marine in 4-strokes Yamahas on a 31 ft center console boat, and their 2-Stroke Injector oil in a 115 Merc Optimax. And their marine grease in all my trailer bearings.
I'm not an Amsoil fanatic, and readily admit that other oils would probably have performed as well, But I haven't had any oil-related failures, and am willing to pay extra for what might be keeping me, and my family, a little more secure when offshore or in the Bahamas, or when towing long distances to get there.
I have had cam lobes wiped in both a Ford Taurus SHO using Castrol Syntec years ago, and in my daughter's Honda CRV that was using whatever the local tire shop was using. Both of those cars were bought used, so I have no way to know how they were treated before we bought them, but we had put quite a few miles on both of them both.
Old Jul 20, 2021 | 09:21 AM
speakerfritz's Avatar
speakerfritz
if your in warranty best bet is to use motorcraft. I know about the laws but ford has deeper pockets than I do and its not worth the headache.
mattymax
Dec 22, 2019 07:47 PM
A/Ox4
General Diesel Discussion
Oct 30, 2013 08:33 PM
AngeliasDad
Sep 15, 2013 10:16 AM
squigler
Oct 26, 2008 02:40 PM
rusty70f100
Oil & Lubrication
Jun 19, 2004 04:34 PM
