Need help with trans lines
Old Jul 15, 2021 | 05:25 PM
Fredboy's Avatar
Fredboy
Ordered from LMCTruck. They sent these lines with I’m pretty sure a nut with a 5/16th thread. How can I get these lines to go into my radiator? They go perfect into my trans case but not my radiator. Been looking for an adapter or something.
Old Jul 15, 2021 | 05:41 PM
Franklin2's Avatar
Franklin2
You need an flare fitting. I am assuming the threads in the radiator are pipe threads. You need to figure out if they are 1/4 pipe threads or 3/8 pipe threads. I am guessing one or the other from the picture. So you need a fitting like the picture below with male pipe threads on one end, and a inverted flare to accept your 5/16 line and nut.
Old Jul 15, 2021 | 05:55 PM
Fredboy's Avatar
Fredboy
just wondering, how may I check what size threads are in the radiator?
Old Jul 16, 2021 | 06:19 AM
FuzzFace2's Avatar
FuzzFace2
I like to use a short pipe of each size to see what fits the radiator side.
Then you can take it with you to get the right fitting.
Dave. ----
Old Jul 16, 2021 | 11:06 AM
Max Capacity's Avatar
Max Capacity
Looking at my 86 with a 302 V8, I'm thinking the thread pitch is 1/4" NPT male adaptor is what you need.
5/16 NPT is not a normal size.
1/4"
3/8"
1/2" NPT is normal.
I replaced my radiator a few years back. the trans lines are what came on my truck.
Old Jul 16, 2021 | 11:13 AM
Fredboy's Avatar
Fredboy
1/4"
3/8"
1/2" NPT is normal.
is this what I need? If not, please point me in the right direction.
Old Jul 16, 2021 | 11:26 AM
Max Capacity
Sorry, what you need is what is shown in post #2, I now figured out the second picture you posted...is the radiator with the adaptor missing.
Most any hardware store will have what you need. in the Plumbing section
The auto parts store may have them too.
Old Jul 16, 2021 | 12:52 PM
Fredboy's Avatar
Fredboy
Forgot to mention, don’t know if it helps but it’s a 351w with a c6
Old Jul 16, 2021 | 01:10 PM
Max Capacity
https://www.google.com/search?q=the+...client=gws-wiz
If you need fittings, The Parker Store will have them. That's who we used at the place I worked.
Old Jul 16, 2021 | 04:30 PM
Franklin2's Avatar
Franklin2
The autoparts store may have it also. How did you get in this predicament? What did it have before? You don't have any type of old fitting?
Dirty Offio
Jul 7, 2017 10:08 PM
abe
Oct 24, 2016 08:01 AM
goldwingflyer
1947 and Older Ford Trucks
Feb 15, 2006 05:09 PM
gatesj
Jan 26, 2006 04:36 PM
48 Ford F4
May 30, 2005 10:07 PM
