2002 E250 Throwing P0175
So far:
Hooked up a fuel pressure gauge, indicated 31 PSI while running. Vacuum removed from regulator showed 41 PSI running. No gas from Regulator vac line. Regulator appears ok. After shutting off the vehicle the fuel pressure climbs to about 38 PSI and stays there for about a half hour, then starts to fall back down around 30 psi and stays there for about 10-15 minutes. I don't suspect the check valve at the fuel pump as I understand that the psi would drop quite quickly? Also, do not suspect leaking injector as the fuel pressure stays around 30 psi for a good 10-15 min after it comes down from its initial increase post shut down.
I'm learning as I go, and I despite multiple searches I have not been able to find a whole lot as it pertains to the P0175 code. Any other ideas? I appreciate any help! Thx
- Faulty front heated oxygen sensor
- Ignition misfiring
- Faulty fuel injectors
- Exhaust gas leaks
- Incorrect fuel pressure
- Faulty Mass Air Flow (MAF) sensor
