Sponsored by: Real Truck
blower motor ground problem
Old Jul 13, 2021 | 06:57 PM
llh's Avatar
llh
I recently had a problem with ac going off and on at random. replaced blower motor , resistor and wire coupler. the compressor is always still on. only blower off. the problem kept happening until I figured out it is the ground to the blower. I ran a new ground to the battery and everything works perfectly but now I cant control the fan. Does anyone know where I might look that it picks up its ground so I could fix the problem properly? I live in Florida so I am thankful I can make it work at all. any info appreciated.
Ford f250 2006 10 cyl lariat
Old Jul 14, 2021 | 05:21 AM
Gyppo Logger's Avatar
Gyppo Logger
Truck? Year, motor all that gradoo
Old Jul 14, 2021 | 09:57 AM
projectSHO89's Avatar
projectSHO89
Remove the kick panels in the cabin and inspect the grounds for body rot, corrosion, or loose connectors. Start on the passenger side.
Remove the extra ground you attached to the blower motor, it's in the wrong place and will cause you to loose control of the blower speed. The ground for the blower has to go thorough the resistor and the blower speed switch for it to work properly.
samw57
1983 - 2012 Ranger & B-Series
Oct 1, 2010 03:52 PM
2000ex
Oct 17, 2007 06:05 AM
nascar88ford
May 31, 2006 09:45 PM
jqp00002
Sep 8, 2005 12:30 PM
buzzer
May 17, 2004 11:01 PM
