Sponsored by: Real Truck
Moog Parts Are Garbage!
Old Jul 12, 2021 | 09:47 PM
reptar0077's Avatar
reptar0077
Thumbs down Moog Parts Are Garbage!
Just wanted to express my frustration with Moog parts & how all never be buying another Moog product again.
Went out to my beater with a heater 01 Camry to rotate my tires & while I looked everything over while I had it apart I noticed my Moog front end stabilizer bar links looked completely shot.
& I'm able to move it way to easy by hand. Granted it may have a couple months left but that's terrible.
I had rebuilt my entire front end 7-8 months ago with all brand new grease able Moog ball joints stabilizer links ect. I baby all my vehicles & don't abuse them at all. The links I replaced were the factory links that had 300k miles on them!!!!!
These have less than 15k on them & were greased every oil change.
I've always read other threads about people bashing on Moog quality & always took it with a grain of salt until now.
I'm about to redo my supers front end & will be avoiding anything with Moog. Hopefully I save someone else the trouble in the future.
Old Jul 12, 2021 | 10:04 PM
Tom's Avatar
Tom
Disappointing, but I’ve heard that about Moog parts from others in recent years. From what I understand, their quality isn’t what it used to be. But it’s worth remembering that the most common time for a part to fail is at the end of its service life or the very beginning. Google the “bathtub curve” if you want some interesting reading.
That’s why I never replace good parts. There’s a good chance those end links would have lasted for the rest of the life of the car if they were still good when you replaced them.
I just replaced the upper control arms in my Expedition because of cracked balljoint boots. I chose Moog parts because they were priced right at Rockauto. So far so good, but it’s only been a month since replacement.
Old Jul 13, 2021 | 05:16 AM
CollinsCD's Avatar
CollinsCD
I had a Moog front hub bearing go bad after replacing it less than two years ago on my Chevy beater car. I went with a higher price Moog part thinking it was worth the extra cost for a quality part. I should have gone with the cheaper part if I knew it would not last.
Very disappointing!
Old Jul 13, 2021 | 06:55 AM
M1A4ME's Avatar
M1A4ME
Sad to hear that.
My youngest son and I rebuilt the front end on his 03 F350 4WD (6" lift and 38" tires) about 6 years ago. No issues since. Maybe the quality issues came up later, or maybe he got lucky.
Old Jul 13, 2021 | 08:18 AM
Mike1's Avatar
Mike1
I replaced the ball joints on on my 03 F350 4x4 about 4 years ago and haven't had any issues, they still look like new. But I have heard that Moog quality is is like a crap shoot any more.
Old Jul 13, 2021 | 08:55 AM
bajaphile's Avatar
bajaphile
So does anyone have recommendations for ball joints and tie rod ends? Stick to Motorcraft parts?
Old Jul 13, 2021 | 09:09 AM
Akley88's Avatar
Akley88
PMF suspension makes some heavy duty tie rods and they offer heavy duty ball joints.
Old Jul 13, 2021 | 09:31 AM
Tom's Avatar
Tom
I think Motorcraft is probably the safest choice for top-quality replacement, but Ford doesn't make many of their own parts. I look for suppliers I know as Tier 1 to the auto industry such as Delphi, Bosch, and a few others. Most of them sell identical parts under their own brand, but it's tough to know which ones are OEM for the specific component you're replacing. I always balance the cost of the replacement with the hassle to repeat the job and how much longer I'll be keeping the vehicle. If I settle for true aftermarket, I think Moog is as good of a choice as any.
Old Jul 13, 2021 | 11:26 AM
leadmic's Avatar
leadmic
Motorcraft that you buy as replacement parts are not the same as OE parts that originally came on the vehicle. Usually lower quality. All automotive manufacturers have different venders for different lines. I was the lead fleet mechanic for a large utility company and found this out years ago. I was shocked and very disappointed. Its a crap shoot when you buy OE parts as to whether they are going to be better or worse then major aftermarket manufacturer parts.
Old Jul 13, 2021 | 11:30 AM
Antonm's Avatar
Antonm
True, but even ISO/ TS/ IATF 16949 suppliers have different standards for aftermarket versus OEM stuff. I spent a couple years as a quality engineer at one Tier one place , then spent some time as a sort of middle manager at another ( both were names I'm sure everyone's heard of). Both had procedures to reduce scrap on parts that failed QA tests for OE by re-running them/ selling them as aftermarket.
Probably still way better than a non -IATF supplier, but not the exact same.
Old Jul 13, 2021 | 02:03 PM
Tom's Avatar
Tom
Originally Posted by Antonm
True, but even ISO/ TS/ IATF 16949 suppliers have different standards for aftermarket versus OEM stuff. I spend a couple years as a quality engineer at one Tier one place , then spent some time as a sort of middle manager at another ( both were names I'm sure everyone's heard of). Both had procedures to reduce scrap on parts that failed QA tests for OE by re-running them/ selling them as aftermarket.
Very interesting, and good information! I always suspected they weren’t identical, but I’ve always had good experiences with them. So I figured they were very similar in quality if nothing else. But your explanation makes sense.
Old Jul 13, 2021 | 06:42 PM
Just Strokin's Avatar
Just Strokin
Ford/Motorcraft puts out request for bids/quotes on parts. The supplier chosen might be USA or might be sublet to China (Ford already uses China parts {Aluminum wheels on SuperDuty trucks}). It is the luck of the draw now days on the quality of parts as most parts now are made outside of the USA. Whether Moog or Motorcraft of NAPA, check your parts for bearing noise or roughness if say it is a front hub before installing it. You need to physically inspect your parts now days and test them as well as possible before installing them. One reason I buy locally or off eBay if they say free returns as the cost of shipping to return bad items is getting more expensive with our current administration wanting to raise taxes and also letting inflation rise,
JMHO and 2 cents
Old Jul 13, 2021 | 07:12 PM
Hotcross's Avatar
Hotcross
What about NAPA parts? I heard from a tech their stuffs as good as OEM, better than Advance or AutoZone. Any opinions/ experience?
Old Jul 13, 2021 | 07:21 PM
Just Strokin
NAPA is like most auto parts stores, they are re-boxers. Most times I found that you paid extra for the name NAPA to be on the box. Like others, they submit requests for parts to be boxed in a NAPA box. Most times these are the lowest cost bidders.
Old Jul 13, 2021 | 08:47 PM
leadmic's Avatar
leadmic
When I was a Fleet tech we used strictly Napa parts as we had a contract with them. We only used their best line of parts and had very good luck with them.
