Sponsored by: Kumho
Brake problems on me ford
Old Oct 30, 2003 | 11:17 PM
Talyn's Avatar
Talyn
Got my 91 f150, and for some reason, the brakefluid decided to get really gay and go out though the drum.
The line is fine.
but when i went to take the drum off (left rear) the drum is stuck on. It's only stuck in one spot.
Kinda curious what would cause all the fluid to pour out of here.
THe crappy part is i'm injured, so its hard for me to work, and i dont have a vehicle to go get parts with.
I have front bakes still *phew* cause i think it started this while i was driveing.
I'm sure i can get the drum off, though I already damaged it a lil with a big hammer. Not in a critical spot though.
so what could this stupid thing be?
and how much am i lookin to spend on parts here?
Old Oct 30, 2003 | 11:27 PM
1982fordf100's Avatar
1982fordf100
Leaking brake fluid from behind the drum, without it coming from the line is a wheel cylinder. Very simple to replace, as far as the drum being stuck on, did you turn the adjuster all the way in to the shoes are not pressing out against the drum? Wheel cylinders are cheap to, maybe 20 bucks. The brake fluid isn't being gay either the seal went bad inside of the wheel cylinder.
Old Oct 31, 2003 | 07:15 AM
ctfuzzy's Avatar
ctfuzzy
Well, come on now - the fluid COULD BE gay.
But leaking out the way it is, is indeed perfectly normal with a wheel cyliner failure.
Old Oct 31, 2003 | 09:13 AM
Talyn's Avatar
Talyn
The drum is stuck on, cause my buddie didn't think either, the ebrake is on. hahaha!!!!
I figured it was something like the wheel cylinder.
Thanks.
Will check my book on how to fix it then go get one. =D
Old Oct 31, 2003 | 11:16 AM
Talyn's Avatar
Talyn
Ouchies.
Can i say screw replaceing the brake shoes till i have the money to redo the breaks?
I just need it to not leak fluid.
This will be fun, i've never taken a drum brake apart.
Old Oct 31, 2003 | 06:15 PM
Talyn's Avatar
Talyn
got lazy, took it to shop. 60 dollar repair.
Mdc9966
Jan 19, 2017 10:13 AM
Olney
1983 - 2012 Ranger & B-Series
Apr 30, 2015 06:30 PM
aidandj
Sep 11, 2013 02:48 PM
rosesrfree4u
Aug 27, 2011 11:43 AM
drew96
Apr 20, 2006 09:48 PM
