More E4OD fun. Manual shift mode?
Old Oct 30, 2003 | 10:28 PM
Holder20's Avatar
Holder20
Bring you up to speed.
Replaced tranny in 90 E350 5.8L.
Purchased a new torque converter and a used tranny from a '91.
Installed it last week. Hooked up the all the connections and checked for leaks. Reverse is great but it wants to take off in 3rd. Will only go to 1st. 2nd. or 3rd. if I manually position the shifter lever. No OD lockout light on the dash either. I know the light works because it will come on briefly when starting.
I know to recheck all the connections again and make sure they are dry but what else should I be looking for?
Thanks
Ignorant E4OD owner.
Old Oct 30, 2003 | 10:59 PM
dieselzen's Avatar
dieselzen
Holder,
The Solenoid block harness connector can become brittle and the wires coming out of it can have the insulation burned or corroded off despite the heat shield being in place. Also, make sure all the pins in the pin block are straight and not bent. Click on my "profile" in blue and send me an email and I'll send you some diagnostic information which may help you now, and in the future.
R.A.
Old Oct 31, 2003 | 09:41 AM
Holder20's Avatar
Holder20
R.A.
Since I have not been a member long enough I can not access your email address. I have updated my profile and allowed my email address to be accessible. Please send me the info.
Found another problem which is probably related. Instead of having a throttle return spring or cable, some genius has put a screen door spring on the throttle body to have it return to idle. I am assuming the cable is supposed to plug into somewhere and not just used as a return spring.
z31freakify
25
Apr 3, 2026 02:58 PM
nick_ct_203
Sep 8, 2016 05:14 PM
Churchwarden
Nov 9, 2015 10:07 AM
shadetreescotty
Jun 24, 2015 04:52 AM
IDIDieselJohn
15
Apr 21, 2015 12:02 AM
