Speedometer not working
Old Jul 10, 2021 | 01:08 PM
spooktn's Avatar
spooktn
I got my 97 5 speed stick 2.3 running fine but the speedo does not work . I changed the fuel filter and saw a lot of fluid and dirt around where I assume the speedo cable hooks up. What do you call this part and how simple or hard is it to replace ?????????
Old Jul 10, 2021 | 01:34 PM
Kruse's Avatar
Kruse
It would be a speed sensor, not a speedometer cable. Your speed sensor could have failed or perhaps rodents chewed through the wires that go to the transmission, for beginning troubleshooting.
Old Jul 11, 2021 | 09:08 AM
pawpaw's Avatar
pawpaw
Hold on, resist tossing parts at the problem based on a hunch. Since this is a 97 & is OBD-2 diagnostics, as suggested a couple of times in the past, use your ELM scan tool & run FORScan diagnostic freeware on your choice of viewing device as discussed here Low Cost ELM Scantool - Ford Truck Enthusiasts Forums (ford-trucks.com) & have it scan for trouble codes, as this combo can query All of the vehicle computer / controllers for trouble code Clues, then post All code Numbers as they can help focus a trouble shoot.
More thoughts for consideration.
Old Jul 11, 2021 | 11:10 AM
spooktn's Avatar
spooktn
Forscan codes this morning after short test drive ,,,,,,,,,,,,, code P0500 - VSS -sensor circuit fault ,,, open or short circuit ,,, worn or damaged drive gear . Code B1352 - ignition key in circuit fault . My money is on damaged drive gear but will test circuit before buying part . Have no idea about Code B1352 ignition key circuit fault . Any ideas on B1352 ??????????????? Will try U-Tube for voltages on VSS they have video on just about anything . LOL
Old Jul 11, 2021 | 11:32 AM
Kruse's Avatar
Kruse
Obviously directed at my post, so I wish to say that under no way, shape or form do I now or ever recommend "throwing parts" at it. And I rereading my post, I don't think I suggested any such thing. I did use the words "could" and "perhaps". I mainly meant to say that: 1: The '97 Ranger does NOT have a speedometer cable, and 2: Look for the simple things first, like a broken wire that goes to the speed sensor. Then, of course, troubleshooting (before parts replacing) begins. BTW, I have a '97 Ranger and rodents did chew on the sensor wires making my speedometer inoperable.
pawpaw's Avatar
pawpaw
Attaboy on running a FORScan code look-see. My 99 New rear differential mounted ABS speed sensor measured 1.91K ohms. The old one was open circuit.
EDIT: As Kruse has posted, your Speed-O is electrically operated by the rear ABS speed sensor, so it, the wiring, electrical connectors pins/sockets & wire crimps also belong on the suspect list.
As Kruse has also stated, critters like to mess with the wiring insulation & broke his. We've had a report of the speed sensor wiring getting mashed, around the bell housing during a tranny removal / install & it caused the wire strands to flex & break under the insulation.
Another member reported the speed sensor wire split wire loom on the rear axle run, came loose, flapped in the wind & caused the wire strands to break under the insulation, about 4" back from the loom end, this caused an intermittent speed-o, as the loose loom containing the faulty wiring waved in the airstream & the broken wire strands made & broke contact.
Old Jul 12, 2021 | 08:56 AM
pawpaw's Avatar
pawpaw
On the Body code B1352 Ignition key circuit fault, look in your FORScan definitions, for a suspect list.
If your having warning chime problems, did they come about recently after some event??? Do the chimes work ok with the key in, or out, or not at all???
Old Jul 13, 2021 | 01:24 PM
spooktn's Avatar
spooktn
Ok I think I found the issue with the B1352 code . Door chimes works if key is on and door open but stops when key is turned off and door open. Chimes also work if headlights are left on and door is open, Can wiggle key cylinder and chimes are off and on as wiggled. Will remove cover under steering wheel and have a look see. Thanks pawpaw I hope to be as good with these old trucks as you are one day !!!!!! Did not understand what that code meant till now LOL.
Old Jul 13, 2021 | 04:25 PM
pawpaw's Avatar
pawpaw
Ok good trouble shooting find & feedback. Members in years past have reported wiring or corrosion problems to the wire connection to the lock cyl case, so have a close look there-abouts. If all checks out with the wire connection, while covers are off so you have better access around the lock cylinder, you might consider spritzing the lock cylinder internally & the key with CRC heavy duty silicone spray & work it in real good with the key & let us know what you find & how it goes.
Old Jul 17, 2021 | 09:09 AM
pawpaw's Avatar
pawpaw
Well spooktn, how is the inoperable speed-o trouble shoot going, 182 curious minds would like to know????
Old Jul 17, 2021 | 09:32 AM
spooktn's Avatar
spooktn
I have not worked on it yet ran into a brake problem,,, think i blew a rear wheel cylinder, More important to stop than know how fast i am going LOL
Old Jul 17, 2021 | 09:39 AM
pawpaw's Avatar
pawpaw
OK, keep us posted on the speed-o & key code trouble shoots !!!
Old Oct 24, 2021 | 01:31 PM
spooktn's Avatar
spooktn
After fixing several other issues I finally got back to the speed-o not working. Fuse is good not broken or chewed wires so I got a new sensor and installed it and still no speed-o. I could not find a you tube video for my exact year. But others I saw showed changing the plastic gear from old sensor to new one .I have no such gear !!!!! I would bet money that the gear is missing and the whole trouble. 5 speed stick and I assume it is supposed to have that plastic gear and clip to hold it on. Am I correct and if so is this a junk yard item have not seen it in Autozone web site !! Please point me in the right direction . Oh and a good spray with electronics cleaner fixed the door chimes problem and key fault . Easy fix after removing cover under steering column .
Old Oct 28, 2021 | 04:26 PM
spooktn's Avatar
spooktn
Here is a pic of a speed sensor with the plastic gear I am talking about. My sensor is on the transmission and the plastic gear is not there . Does it supposed to have one and if so is this a junk yard part. Are they all the same want speedo to so the right speed if this plastic gear is the issue. Can not count teeth on gear I dont have one !!! OOOOPS sorry cant copy picture
Old Oct 28, 2021 | 05:29 PM
spooktn's Avatar
spooktn
OK found the gear on EBAY but not the clip that holds it. Gear fits manual and auto but comes with several different number of teeth . Help !!!!!!! LOL
