Sponsored by: Real Truck
Intermittent A/C issues
Old Jul 8, 2021 | 07:01 PM
ManiacMJ's Avatar
ManiacMJ
4wd Low
I have a 2004 F350 V10. Recently replaced compressor and Dryer. Noticed freon was low, so added a full can. Air blows cold and strong until i drive for 30-50 miles at highway speeds, then it gets warm and eventually starts blowing very weak. Once i let it sit for a bit, back to cold and strong. I generally drive from about 5500 feet down to the valley at 1500 feet where it is significantly warmer when this happens. Any ideas what may be causing this? Many thanks!
Old Jul 9, 2021 | 06:23 AM
projectSHO89's Avatar
projectSHO89
Your evaporator is freezing up, either from an incorrect refrigerant charge or from a compressor clutch that is not cycling properly.
How, pray tell, does one determine that "the freon was low"?
Old Jul 12, 2021 | 02:25 PM
ManiacMJ's Avatar
ManiacMJ
4wd Low
when i connected the refrigerant can, the gauge on the can was well below where it says it should have been
Old Jul 12, 2021 | 03:59 PM
projectSHO89
At best, that would be an inclusive indication. See the HVAC FAQs linked to in my signature.
Have the system properly evacuated and then correctly charged by weight to the correct amount.
Old Jul 13, 2021 | 07:46 AM
Fefanatic's Avatar
Fefanatic
That's your first mistake. Chances are you overfilled your system. As Sho posted above, have it properly evacuated and recharged using measuring equipment. FWIW, I've seen this too many times when customers try to charge their ac themselves. Those recharge kits have made me thousands of $$ over the years. You can't count on that gauge being accurate.
Old Jul 24, 2021 | 05:50 PM
ManiacMJ's Avatar
ManiacMJ
4wd Low
thanks for the info
URDADDY
Jun 4, 2020 05:20 PM
jccapri
23
Jul 28, 2013 08:47 PM
KSims1868
May 27, 2008 11:54 AM
zman764
1997 - 2003 F150
Apr 16, 2006 10:50 PM
jetnjmy
1997 - 2003 F150
Aug 19, 2003 10:27 PM
