Sponsored by: Real Truck
NEED HELP PLEASE!!!
Old Jul 8, 2021 | 03:32 PM
drlugomelendez's Avatar
drlugomelendez
NEED HELP PLEASE!!!
Hello everybody ! I'm new to the forum thanks for accepting me!
I bought this 2014 Ford E-350 Cutaway shuttle bus, my intention is to turn it into a mobile home, the vehicle was bought at auction, it was used as public transportation in Pennsylvania, it had a security camera system of which only the cables remain, it has two batteries and many other accessories that are not used.
I would like to know, can an inverter be installed? I would like the additional batteries that I am going to install to charge with the alternator, could I install it in the second battery? or do I need to install it on the main battery? Would you need to use an isolator? Or having two batteries already has it installed from the factory? By having two batteries would it be 12 or 24 volts? Does anyone know of an electrical diagram?
Can someone please help me ? It's my first Ford vehicle and I don't know anything about them
Thanks to all in advance !!
Old Jul 12, 2021 | 09:56 AM
Log Hog Kust'em's Avatar
Log Hog Kust'em
you can run an inverter. Follow manufacture's directions. Most motorhomes have two battery systems. One for the chassis (what you have) and one for the house. Use deep cycle batteries for the house (lithium are better and cost more) wired in parrallel to maintain 12 volts (not 24) You can gain more, and better, information, on RV forums. Good luck
Old Jul 12, 2021 | 04:36 PM
Gyppo Logger's Avatar
Gyppo Logger
Just curious, which motor is in that?
Old Jul 12, 2021 | 05:11 PM
m-chan68's Avatar
m-chan68
I'm going to go out on a limb and guess the 6.8L V10 2V. Doubtful the 5.4L V8 2V would be used to move something that heavy.
Old Jul 12, 2021 | 07:18 PM
bajaphile's Avatar
bajaphile
A simple way to test if you have an isolator, which should be installed, is to measure each battery voltage when the vehicle is off. They will probably measure a different voltage. Once the engine is running, the isolator should see the higher volts and then open so both batteries are being charged. I would simply follow the auxiliary battery positive wire and you should find the isolator. To beef up your house battery bank, you can run additional 12V batteries in parallel to that auxiliary bank. Or what most people do is run 6V in series to 12V as they are true deep cycle and are cheaper. (Other option is Lithium but you'll be spending close to $1k).
As stated above, you'll probably want to check into an RV forum for more information. There are many RV's powered by the Ford Triton V10.
kr98664
May 16, 2021 07:44 PM
Rockinfigs
All Things Towing
Jun 22, 2020 07:07 PM
TooManyToys.
Jan 29, 2020 08:27 AM
flhx06
18
Sep 19, 2017 12:32 PM
ChunderDownUnder
Australia Chapter
28
Mar 19, 2013 03:12 AM
