oil temps
Old Jul 6, 2021 | 08:11 PM
Mich6.0's Avatar
Mich6.0
oil temps
Any body else notice higher oil temps with 5w40 syth. , just switched back to 15w40 for a couple oil changes and thought i had some oil cooler clogging going on ,but the temps dropped back to normal with the heavier oil. Don't know if it cleared it's self or it was a flaw with the sensor, I know the temps were jumping around a few days ago.
Old Jul 7, 2021 | 08:07 AM
bismic's Avatar
bismic
15W40 is a 40 weight, and so is 5W40. At engine temps, the weight is the same.
Old Jul 7, 2021 | 01:39 PM
FiveOJester's Avatar
FiveOJester
What kind of difference are you seeing? So many variables go into oil temp based on how you are running the engine it can be all over the place.
Old Jul 7, 2021 | 07:23 PM
Mich6.0's Avatar
Mich6.0
eot 230 at hwy speeds with 5w40 and 15w 40 the temps are right with ect 192 -195 , both cooled down to normal within ten minutes or so, dont know if something was blocking the passage or not, things have been running ok lately
Old Jul 8, 2021 | 01:53 PM
FiveOJester
If you are running 230 EOT at highway speeds with a 192-195 ECT your oil cooler is most definitely plugged. Get the system flushed and a new oil cooler installed ASAP! With that high of EOT you're starting to risk long term damage to the engine.
Old Jul 8, 2021 | 07:51 PM
Mich6.0's Avatar
Mich6.0
Well switch oil to 15w40 at oil change time and temps came back to normal , didn't do anything else, got me puzzled .
Omahastro1
May 12, 2009 09:54 AM
Itsmejoe231
1997 - 2003 F150
Aug 31, 2005 04:11 PM
86bronco2jeff
Oil & Lubrication
Mar 25, 2003 11:32 PM
bigred78
Dec 23, 2001 11:28 AM
