Hey guys, I’m gonna start a thread for my questions on these Ol’ 7.3’s. Lord knows I have plenty of them lol.
The first couple I have are 1. I have an intermittent ABS light, it pops up at first startup but if I drive a couple feet and restart the truck it’ll go away. But if it sits not running any longer than 15 minutes it comes back on startup. I don’t mind it but I hate seeing that amber light lol.
2. I do A LOT of highway driving, and I live in Nevada so most of the highways I use are 80 mph, with that being said cruising at 80 I’m pushing at 2900 rpm. I’m looking to lower my cruising rpms. I was looking at going the GearVenders OD route but they’re pretty spendy. Are there any other routes I could take? I heard bigger tires will help but I’d have to recalibrate the PSOM. Any input on either of these is appreciated.
Well gentlemen, I have a few more spitballs to bounce off of ya. Have yet to play with a regear or tires. Haven’t had to put my Ol’Girl on the road too much this past year, that being said there’s a couple issues I’d like to address before work picks back up and I have to hop on the road.
Cruise Control: She’s pretty old being as she’s a 94 but did the Millennial AntiTheft models come with Cruise? I have the cruise buttons on my wheel.
Intermittent Check Engine Light: I gave her some love and threw some new FFD 180/30’s in it in about April of last year, drove it with no tunes for a bit to get the injectors settled in but here a few months ago I got some Jelibuilt tunes and if I go past 1/2 throttle on any of my power adder tunes I get a check engine light. No loss of power no funky sounds just a light.
Clunky Sounds after warm: When I get off the road and sit idling I get a pretty violent shutter every now and then, it seems to come from the engine but I have no idea. And then on top of that, I get a loud clunk from what seems like my trans at idle. A buddy of mine said it’s the clutch fork but I’m not sure.
I know she’s a pretty lengthy list of stuff but any and all input is welcome and much appreciated. Thanks guys!
Cruise Control: She’s pretty old being as she’s a 94 but did the Millennial AntiTheft models come with Cruise? I have the cruise buttons on my wheel.!
Yes
Originally Posted by Khris Jackson
Intermittent Check Engine Light: I gave her some love and threw some new FFD 180/30’s in it in about April of last year, drove it with no tunes for a bit to get the injectors settled in but here a few months ago I got some Jelibuilt tunes and if I go past 1/2 throttle on any of my power adder tunes I get a check engine light. No loss of power no funky sounds just a light.!
New injectors + Tunes, not enough high pressure oil.
You'll need to upgrade your HPOP. T500 from Terminator is good choice.
Clunky Sounds after warm: When I get off the road and sit idling I get a pretty violent shutter every now and then, it seems to come from the engine but I have no idea. And then on top of that, I get a loud clunk from what seems like my trans at idle. A buddy of mine said it’s the clutch fork but I’m not sure.!
If you replaced the clutch, you're probably hearing gear rollover from the engine vibration going through the clutch. The DMF stops a lot of this, but if you swap in a regular flywheel, you get gear rollover sounds from the motor resonating into the trans.
I get the same thing fairly often. It goes away if I feather the accelerator. The tach reads normal. i have no idea if it is fuel, oil pressure, or wires, but it feels like misfiring. curious what others think.
Usually broken spring(s) in injectors causing a rough idle.
How much boost are you putting out while accelerating? It's possible it's too much for the MAP, a boost relief valve will help with this so the computer only sees what you allow but you still get full boost. I never had the check engine come on, but some have reported this issue.
That's really only an issue if youre running like 180's and up. Usually more to pay attention on 238's.
Now a bad map sensor does some weeeeeird *** stuff though. But not at idle.
If you get rough idle, it's usually broken springs/ worn injectors.
The trucks only need like 45-50psi to idle, but they do everything better in the 60-75psi fuel range.
Same with oil, if you're not running enough oil, it doesn't care at idle, the DC%'s are so low the stock 15 can keep up no problem.
So if you add a smidge of fuel and it cleans it up a bit, then the shudder is most likely injector related. or if anything fuel pressure related. but probably not. If it drives good, but idles rough, its probably injector springs or worn out injectors.
So if you add a smidge of fuel and it cleans it up a bit, then the shudder is most likely injector related. or if anything fuel pressure related. but probably not. If it drives good, but idles rough, its probably injector springs or worn out injectors.[/QUOTE]
Injectors probably have just over 10,000 on them. It has something to do with load if I slowly release the clutch at like a stop light it’ll creep and if I just barely blip the brake and load it down a little it does the shutter. Could it be IPR related? I had a bad IPR just after I bought it a year and a half ago, I put an Alliant replacement in not knowing any better. Just good for thought.
