well that bites
Old Jul 3, 2021 | 03:11 PM
jcnorton's Avatar
jcnorton
OK good info, thanks. So now I'm going to go try it, I'll bet I get a noise from the right seat
Old Jul 4, 2021 | 05:49 AM
RTM's Avatar
RTM
I replaced my clutches and I never had any chatter issues with the new clutches. It's not as easy to change the clutches as one might think. You need to be able to compress the preloaded spring/washer in order to get the spider gears back in place. I found a video that showed a guy using a carriage bolt with a nut and a few washers and used it to compress the preloaded washer. My understanding is the new ford clutches eliminated the chatter issues.
Old Jul 4, 2021 | 07:58 AM
jcnorton's Avatar
jcnorton
OK thanks, I don't think I'll try that myself. The older I get the less adventuresome I've become. I'll probably just go with it as is, haven't got around to testing it yet as it doesn't get driven a lot during "mustang" weather!
Old Jul 4, 2021 | 11:37 AM
tbear853's Avatar
tbear853
I found it too, but I forgot to mention the bolt tool he made. Looking through the comments I see that one fella used all-thread rod inserted through an open axle tube after removing the axle, and some nuts & washers ... to pull the spiders apart. Good points about marking too.
I think for snow, ice, crowned roads, I prefer limited slip over locking types.
Old Jul 6, 2021 | 11:47 AM
Bob Sagget's Avatar
Bob Sagget
Lol, could be worse. I bought my 2010 last year and was really excited to finally have a factory installed Elocker. I found it a little odd that the dealer specifically mentioned about having the axle rebuilt through a local shop and the shop only saying that they knew they worked on it but couldn't find paperwork saying what. About 3 weeks later I discovered they just swapped in an LSD because the Elocker was grenaded. Needless to say, they tried to cheap out...took the truck back and had them properly install an Elocker. The LSD worked fine. But I bought my truck for the specific reason of it having the Elocker and that's what I paid for over the cost of an STX or base 4x4.
Old Jul 6, 2021 | 03:55 PM
jcnorton's Avatar
jcnorton
Right foot test says it's working, whole lot of WTF over nothing . oh well it was entertaining and informative at least!
Old Jul 6, 2021 | 04:03 PM
ford390gashog's Avatar
ford390gashog
Well in 2010 there was no e locker. That didn't happen until the 2011 MY.
Old Jul 7, 2021 | 11:51 AM
gDMJoe's Avatar
gDMJoe
Arrow
ford390gashog - Well in 2010 there was no e locker. That didn't happen until the 2011 MY.
According to the 2010 F-150 order guide (05/12/2009) the 3.73E-lock (XL6 code) was S(tandard) on the FX4.
jniolon
22
Dec 23, 2019 05:58 PM
landcrazy
Jan 4, 2017 05:11 PM
will_sc
Jun 8, 2014 05:47 PM
snaponprofile
1983 - 2012 Ranger & B-Series
May 26, 2012 03:55 PM
FarmingFord
Jul 8, 2008 06:23 AM
