Diagnosctic help needed
Old Jun 29, 2021 | 08:19 PM
1L243's Avatar
1L243
I have a 1999 7.3 F250 2WD it ihas 229,000 miles. The original transmission.
I'm getting a little clunk sound from a start. It's a sight sound but you can almost feel it. Also if i'm moving along at speed and take my foot off the gas same thing and when I give gas same thing. The transmission shifts smooth with no apparent problems.
It sound like it coming from behind the transmission but no way to know for sure. I was thinking maybe the center drive shaft bearing?
Thoughts?
Old Jun 30, 2021 | 02:08 AM
85e150's Avatar
85e150
Check the bearing. Check the u joints. Check all slip splines. Does your transmission have a slip yoke or a fixed flange?
Old Jun 30, 2021 | 03:22 AM
1L243's Avatar
1L243
It's a long bed it has a front slip joint that then a section of shaft to a center bearing U joint. Then the front of the rear shaft looks like another slip joint covered with a rubber dust sleeve then to the rear U joint.
A visual inspection shows nothing obvious.
Old Jul 1, 2021 | 12:34 AM
85e150's Avatar
85e150
Lock brakes, chock wheels, find a TRUSTED assistant. Have them shift P to R to N to D as you observe the drive shaft, cross members, differential etc. Repeat until you see a problem. No problem? Drive it.
Old Jul 2, 2021 | 05:29 AM
JWA's Avatar
JWA
^^^Or even better find a lift that contacts the frame and do that same process with wheels off the ground. Otherwise the emphasis would be on TRUSTED assistant.
The_Josh_Bear
13
Jul 5, 2018 02:29 PM
1L243
Apr 14, 2015 09:05 PM
meck1
1983 - 2012 Ranger & B-Series
Aug 24, 2013 05:56 PM
H.T. Mills
Sep 16, 2010 08:08 PM
rlh
1978 - 1996 Big Bronco
Jan 19, 2004 11:44 PM
