Mazda tranny
Old Oct 30, 2003 | 04:56 PM
opporll's Avatar
opporll
Mazda tranny
The door sticker on my 94 F150 says my tranny is "M" im asuming this means I have the mazda 5 speed. anyways I was wondering if sombody could explain how to drain and refill the oil in it, and what kind of oil should be used.
thanks
Old Oct 31, 2003 | 12:59 AM
PatHB's Avatar
PatHB
Hey opporll, if you look at the driver's side of the gear box, you will notice 2 plugs-1 near the top and another at the bottom, they may even be gold toned. Bottom is the drain plug, top is the fill. I believe the book calls for Mercon or some type of Dexron auto trans fluid. Once you get the fluid, fill until it just trickles out of the upper (fill) plug and you should be good to go. I also know that the plug threads are very fine, be careful replacing them.
Old Oct 31, 2003 | 02:23 PM
opporll's Avatar
opporll
do you seriously put auto tranny fluid in a M5OD?
Old Oct 31, 2003 | 06:40 PM
Silver Streak's Avatar
Silver Streak
Yes. Most manual trannies made since the late 70's-early 80's use ATF. I run Amsoil synthetic in mine. It's pricey, but not as pricey as a new M5OD; I've been there. It shifts a ton better with the synthetic in it.
Old Nov 3, 2003 | 07:31 PM
924x2150's Avatar
924x2150
If it makes you feel any better, I just filled my Ford/Mazda 91 Probes' MTX with Mercon Auto tranny fluid. That's what the book told me to do. The car runs and shifts smooth as a babies buttocks.My 87 Stang BorgWarner MTX used 90 weight gear oil. That was the last car I owned that needed gear oil in the tranny.
Old Nov 4, 2003 | 03:15 PM
nacoa's Avatar
nacoa
I just put 5w 30 syn motor oil in mine, shifts smooth and no noise.
TXKaiser
Mar 22, 2007 11:15 PM
mazdafonz3000
1983 - 2012 Ranger & B-Series
Nov 12, 2006 09:25 AM
4.9LFord
Apr 20, 2005 07:30 PM
hl649
Aug 9, 2002 12:25 PM
ColoradoMan
Jun 26, 2001 02:03 PM
