Torque converter not locking up
Old Jun 28, 2021 | 08:20 PM
gixxer1974's Avatar
gixxer1974
I'm sorry, its another one of those threads.
I have an 02 2wd with a 7.3. installed an edge monitor on it a few years ago. has never shown the lock symbol in the gear selection screen.
I read on here that tail lights can cause an issue with this so I checked, all bulbs are good and the correct number, and not LED bulbs.
truck drove ok just got Crappy mileage. mostly used as a tow rig for a travel trailer and always to with O/D off so I didn't worry about it too much, assumed it was an internal trans problem, and didn't have the extra money to have it fixed.
after years, and many miles on it, First gear started slipping and reverse as well. I knew I had to have it rebuilt, and figured that the T/C lockup would be fixed at the time because I assumed it was in the trans.
Took the truck to a reputable local Trans shop, had it built for towing and a billet torque converter installed.
Still no lock up. after looking at a bunch of threads on here trying not to be "that guy" who just posts the question without trying to find the answer, I came across several possabilities for parts/reasons for this. I also came across several suggestions for the A/E scanner with the ford enhanced pack from RiffRaff. So instead of just shotgunning parts that I can't really afford and hopping for the best I ordered the scanner. but I don't know exactly what to look for or what the readings should be.
I'm hopping someone will be able to tell me exactly what sensors I need to be reading, and What the values should be, and hopefully also point me towards a resource to learn how to use this software myself over time.
one thing I found in the list of inputs was "unlock converter for traction control" and it went red with a value of "1" when the truck got up to about 50 mph
The truck is mostly stock with a hydra and some full force stage 1 injectors (had a bad injector, so i upgraded them all) and the tunes to support them, but the problem was the same with the stock injectors and tunes as well so I doubt that's it tunes.
can anybody help walk me through diagnosing the problem with the A/E scanner so I can not only fix it, but learn to know what I don't know?
Old Jun 28, 2021 | 09:29 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If the converter doesn't lock, it will set codes. What codes are stored in the PCM?
Old Jun 28, 2021 | 10:35 PM
gixxer1974's Avatar
gixxer1974
p1000 other than that..
none
over the years I have had a code for the glow plug relay, and one for the cam position sensor. but there are no codes except the one
Old Jun 29, 2021 | 07:22 AM
Mark Kovalsky
Then the torque converter is locking up, If it doesn't lock, it sets a code.
Why do you think it isn't locking?
Old Jun 29, 2021 | 11:53 AM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
On my V10 there is a PID i monitor in my Torque Display called TC Slip, I can feel the TC lock, and when it does the TC Slip value drops down to like 1-5, where as when its not locked, it reads in the hundreds, sometimes up to 1500.
It is indicating how much RPM is being allowed to slip at the Torque Converter. Easy way to tell if its locked or not.
Old Jun 29, 2021 | 01:32 PM
gixxer1974's Avatar
gixxer1974
I have an edge cts monitor that has only shown lockup 1 time in 5 years (in 2018 when I was toing a heavy load up a long hill and the trans got hot). I don't "feel" the lockup after it shifts into 4th, and also yesterday my A/E scanner shows about 400 rpm torque converter slip on a new trans on the freeway. If I understand lockup correctly, that number should be closer to zero right?
Old Jun 29, 2021 | 02:01 PM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
You do realize that the Torque Converter is not inside the transmission, but rather is a seperate item, between the engine and transmission, yes? It is possible, but not a good idea to have a transmission rebuilt, but not the torque converter, was the converter replaced/rebuilt with the trans???
Old Jun 29, 2021 | 02:23 PM
gixxer1974's Avatar
gixxer1974
yes a billet torque converter was installed with the rebuild
Old Jun 29, 2021 | 04:16 PM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
Perhaps the converter has an issue, I have only ever used factory converters for my automatic vehicles, and my GT is stick with a RAM HDX clutch so whole different ball game.
Old Jun 30, 2021 | 12:51 PM
carbon coupe's Avatar
carbon coupe
Im no expert but in the computer world, a 1 usually means true or on. So in this case, it looks like its programmed to NOT lock the convertor.
Old Jun 30, 2021 | 12:54 PM
carbon coupe
I have a billet unit in mine and I can definitely feel it lock up. Wife asked me "why do drive like that, just be smooth"... I had to explain it to her. It is a bit annoying sometimes but nothing I can do about it.
Old Jun 30, 2021 | 01:06 PM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
I wonder if that truck has traction control and the TC is malfunctioning, such as a bad wheel sensor or something, such that it is not able to accurately read the conditions at each wheel.
Old Jun 30, 2021 | 04:04 PM
gixxer1974's Avatar
gixxer1974
that was my thought, however I can't seem to find any info on ford excursions having traction control, So I don't know/understand where to look and what would cause that issue
sowaxeman
15
Jun 21, 2017 12:54 PM
BadDogKuzz
132
Apr 2, 2015 10:15 AM
JOHN2001
15
Feb 5, 2014 07:02 PM
egalaxie
Dec 22, 2007 06:55 PM
E-350cargo
Aug 15, 2003 09:25 PM
