P2309
Old Jun 26, 2021 | 06:09 PM
Okiepa's Avatar
Okiepa
P2309
I have a 2011 F150 3.5L V6 Ecoboost with 115K miles. I've been dealing with an issue with my truck for over a year now. The issue began in April of last year as soon as it started to get hot and humid here in Oklahoma. The symptoms only present when it is hot/humid and the A/C is on. The CEL is currently lit and gives P2309. I notice it most when I am driving around town where I encounter stop signs and lights, lots of stop and go.
The first thing I notice is that the A/C starts blowing warm air, then the truck has a loss of acceleration power and will shake when I give it gas. I have also noticed that during the power loss I can have it up to 3K RPMs and it will not properly shift gear from third into fourth and up.
The winter before this began I had the spark plugs changed at the dealer at 80K miles. I have had the truck for the last six years and have maintained it very well with regular fluid changes, etc. I have ensured all of my plugs are gaped in spec and are not fouled. I have swapped all of my coils to help rule out the low voltage condition as indicated by the P-code, all are working and have good continuity.
I've had it to two different local Ford dealers in this time frame. They both "can't find the cause". I’ll be honest upfront and say that I am not the most mechanically inclined guy out there, but I know enough to get by. I am at a loss at this point. Any help/advice you can give would be great. Thanks.
Old Jun 26, 2021 | 06:19 PM
85e150's Avatar
85e150
Thread moved.
Welcome to FTE.
Your thread is moved here as you have a specific issue with the 2011 F150, which is covered in this forum vs. the General forums.
Since this happens when heat and humidity are factors, I think you should concentrate on connections. Any connection, anywhere up and down the harness etc would be suspect.
https://www.engine-codes.com/p2309.html
How did you get the code? Any other codes, now or earlier?
Stand by for othes to pipe in.....
Old Jun 27, 2021 | 09:25 PM
Okiepa's Avatar
Okiepa
RE: P2309
Thanks for your reply. No other codes have ever been present. I bought a code reader from harbor freight. The dealer confirmed the code as correct.
Old Jun 27, 2021 | 10:31 PM
85e150's Avatar
85e150
OK so all connections and GROUNDS. Make sure you don't have loose or otherwised compromised ground anywhere.
RSCHAP1
Nov 25, 2019 11:30 AM
jacknbella
2009 - 2014 F150
Nov 26, 2011 06:13 AM
ford1977owner
16
Oct 14, 2010 11:00 AM
turnrjr
Jul 9, 2009 08:09 PM
97E150
Modular V8 (4.6L, 5.4L)
Sep 21, 2005 07:43 PM
