Sponsored by: Real Truck
rear rotors
Old Jun 25, 2021 | 06:43 PM
olyellow's Avatar
olyellow
rear rotors
trying to replace the rear rotors on my f350 does anyone know what size e socket to get the rotors off the hub
Old Jun 25, 2021 | 07:37 PM
IDI Diesel's Avatar
IDI Diesel
The rotor isn't bolted to the hub.... It's a snug fit between the hub and ID of the rotor though. A small amount of rust builds and requires force to break it free.
Old Jun 26, 2021 | 09:20 AM
bajaphile's Avatar
bajaphile
The correct size socket is a 5lb sledge hammer ; )
Old Jun 26, 2021 | 12:34 PM
SnowPlowDriver's Avatar
SnowPlowDriver
take a 5lb hammer and beat between the studs.The shock may break it loose.
Old Jun 27, 2021 | 09:20 AM
olyellow's Avatar
olyellow
rotors
the rotor is bolted to the inside of the hub I found out you need an e18 torx socket to remove the six bolts
Old Jun 28, 2021 | 02:10 AM
SDSC4X4's Avatar
SDSC4X4
When you put it together, coat the mating surfaces with high-temperature anti sieze compound. Makes future removals a snap!
If I had a new truck this is one of the first things I would do to all four rotors!
Old Jun 28, 2021 | 08:34 AM
99powerstrokedF250's Avatar
99powerstrokedF250
What year truck is this? My '03 and '04 did not have the rotors bolted to the hubs. However, the e-brake assembly had to be compressed slightly to get the rotors off.
Old Jun 28, 2021 | 01:19 PM
m-chan68's Avatar
m-chan68
The OP obviously has an F-350 DRW. SRW trucks have rear brake rotors that knock off once the brake caliper and anchor plate are removed. On DRW trucks, the axle shaft needs to be removed, along with the hub retaining special ratcheting lock nut, then removed as an assembly after which the two are separated by the eight E18 female Torx fasteners.
LittleRadio
Jul 5, 2011 07:41 PM
61 uni
Jul 4, 2009 07:36 PM
BlackFX4Screw
2004 - 2008 F150
Apr 15, 2009 10:46 AM
neilc88
Jul 10, 2006 12:21 PM
kchemers
May 24, 2005 05:43 PM
