Drum brake expert help please
Old Jun 24, 2021 | 05:07 AM
6 by 8's Avatar
6 by 8
Please accept my apologies for wasting your time. I'm an idiot.
I didn't pay attention to detail and immediately assumed 2WD. Duh !
Study Flecker's pictures and comments.
Your cylinder pins do indeed seem to be wonky.
Also, check the shiny bit that sits around the pin which the springs attach to. Yours is upside down compared to Flecker's.
Old Jun 24, 2021 | 07:50 AM
somethingclever's Avatar
somethingclever
1.) pulling to the right with steering wheel not turning - check rear brakes
2.) pulling to the right with steering wheel also turning - check front brakes
Which do you exhibit when you let go of the steering wheel and hit the brakes?
Old Jun 24, 2021 | 08:05 AM
Truckerbase's Avatar
Truckerbase
Driving with hands off steering wheel, braking sharply causes wheel to turn right.
Old Jun 24, 2021 | 10:21 AM
68Flareside240's Avatar
68Flareside240
I don't know that the part number is stamped on them, but it is entirely possible you got the wrong shoes for the applications, especially if you picked them up from a chain parts store. I have had really good luck with local independent stores, and also ordering from Rock Auto.
The pictures of the right sight potentially explain the problem. As stated, it seems they are doing most of the braking work.
Old Jun 24, 2021 | 11:52 AM
77 HOS's Avatar
77 HOS
Maybe I missed it and if so sorry but verified that the problem os not with the right but maybe the left is not working causing the right only to grab causing the pull/dive to the right and wheel turning.
Old Jun 24, 2021 | 02:32 PM
moose4x4's Avatar
moose4x4
FTE Remembers
Check the hoses.
Old Jun 24, 2021 | 04:20 PM
tbear853's Avatar
tbear853
Look at Flecker's photos, easy to see his front most shoes are shorter lining ... look at lining as relates to the end near the adjuster. Looking at yours, all 4 shoes look the same. It's almost like somebody came in to a store and open boxes up to compare, then mixed the contents up trying to put 4 long shoes in one box, and 4 short shoes likely in some other box. ... then the boxes got put back on the shelf. I've seen it unfold and interrupted guys before at my store. At first look I thought you had put both long shoes on the left, but then I saw your other side photo.
Hoses bear inspection too, Bleeding is important if air is suspected, and adjustment. I install drums when I've adjusted enough to slide drums over shoes, then tighten up manually to a tight but moveable place, then I back off to get just a scraping sound as I rotate the drum.
I don't recall seeing drum brakes with same size shoes front and rear though. The shorter shoe gets pulled away from the anchor under application and is pushed towards the adjuster which pushes the other shoe in tight to the anchor.
Old Jun 24, 2021 | 10:23 PM
Truckerbase
Originally Posted by tbear853
Look at Flecker's photos, easy to see his front most shoes are shorter lining ... look at lining as relates to she end near the adjuster. Looking at yours, all 4 shoes look the same. It's almost like somebody came in to a store and open boxes up to compare, then mixed the contents up trying to put 4 long shoes in one box, and 4 short shoes likely in some other box. ... then the boxes got put back on the shelf. I've seen it unfold and interrupted guys before at my store. At first look I thought you had put both long shoes on the left, but then I saw your other side photo.
Thanks for all the responses. I’m going to take these photos back to the o’reillys I bought them from, and to my autozone locally to see what I can do, or whether there is a way to identify these pads. Since I was forced to replace back brake lines, all 4 brakes were flushed and bled, but the rubber lines are original, so I’ll look into replacing those. I hope not; I hate replacing brake lines with a passion, particularly on an old and rusted out original system like this truck. Replace one line, break the next line or fitting and have to replace the next and the next….
Old Jun 24, 2021 | 11:41 PM
DB429SCJ's Avatar
DB429SCJ
tbear853 is right. The shoes in #1 and #7 all appear to be secondary(longer) shoes. They could have been boxed wrong at the factory. The shoes in pic #5 show a primary (shorter) and secondary(longer) shoe.. The primary shoe always goes toward the front of the vehicle. There is no 2WD shoe,73-79 F100/150 2WD trucks were equipped with front disc brakes. Some good videos;check out "types of drum brake systems".https://www.brakepartsinc.com/raybes...to-videos.html
Old Jun 25, 2021 | 04:09 AM
Truckerbase
Thank you, sir!
ptexrican
Nov 13, 2018 05:31 PM
KRinAZ
Apr 2, 2018 12:22 PM
MainetoDC
24
Oct 28, 2017 10:40 AM
robertbruce
Mar 8, 2013 04:04 PM
ctubutis
Sep 11, 2009 11:58 AM
