PAGING Pirate alignment specs for lifted Excursion
Old Jun 23, 2021 | 04:11 PM
palacios289's Avatar
palacios289
Pirate, please share your recommended alignment specs for a 4 inch lifted Excursion. I am finally swapping steering gear to Blue Top. I currently have the 2 degree caster shims installed. Looking for the ideal alignment specs to minimize wander. Thanks in advance.
Old Jun 24, 2021 | 01:56 PM
JAck19's Avatar
JAck19
This post should have all of the details you're looking for
Old Jun 24, 2021 | 04:46 PM
palacios289
thank you Jack. I do have a question. I just got the truck aligned after steering gear install.
I notice on my alignment sheet that the toe is set to -.03 toe. Is that toe out? do I want +.03 toe for toe out?
Old Jun 25, 2021 | 11:43 AM
pirate4x4_camo's Avatar
pirate4x4_camo
-.03* is Negative Toe or Toe out.
you want +.03* which is Positive Toe or Toe In.
Factory “spec” allows for toe out but in my experience the Excursion tracks better with toe in.
Old Jun 25, 2021 | 12:32 PM
palacios289
thanks Pirate. Yes I’m taking it back to correct the toe. So far the BlueTop steering gear is light years better than stock steering gear
Old Jun 25, 2021 | 12:55 PM
pirate4x4_camo
hate to burst your bubble but blue/red top are stock steering gears. They are simply stock boxes that have been rebuilt to bring them back into tolerance.
but no doubt any worn out part is going to suck compared to one that is sloppy.
blue/red do a nice job rebuilding them but they are still “stock”
Old Jun 25, 2021 | 01:01 PM
palacios289
no doubt they are a stock steering gear box. But I figured they have to be way better than the Auto part store “rebuilds”.
mine wasn’t leaking but the amount of play and memory steer was just out of control.
I checked the rest of the front suspension and it was all good. The steering okay was strictly from the steering gear.
Old Jun 25, 2021 | 01:19 PM
pirate4x4_camo
understood, I just get nit picky on the details.
are they better than auto parts rebuilds ? some are some are not. the problem with auto parts rebuilds is you don't know which company is building them.
I had a Gear from Autozone that was every bit as good as the color tops. I had to return 2 motorcraft boxes in a row, you just don't know until the thing is in your hands.
I think what you really get with the color tops is consistiency and probility. that said I have had a red top on my personal Excursion for over 10 years.
Old Jun 25, 2021 | 01:24 PM
palacios289
that you are very correct on Motorcraft. I had a buddy that wrenches at Ford have to replace 2 as well. Only on the third Motorcraft box was the steering correct.
I’m just happy that I got a good one from Blue top. (Knock on wood). Just need to get the alignment fine-tuned and I will be good to go.
Old Jun 25, 2021 | 01:47 PM
pirate4x4_camo
post you complete alignments specs or a pic of the print out.
I would like to see the before and after details.
Old Jun 29, 2021 | 01:06 PM
palacios289
I am waiting at the shop. They kept on insisting that negative toe measurement was toe in. 🤦‍♂️
I insisted just set it at Positive 0.03 and I’d be on my way.
Old Jun 29, 2021 | 02:06 PM
palacios289
UPDATE!
Success. After “debating” with the shop about negative toe equaling toe out, I got them to adjust me to positive toe. Tech at the shop invited me out to the shop and showed my on the screen that the toe was now set to Positive .05. I told him this was fine.
i drove the Excursion home, and immediately noticed Improved steering. Gone is the dartiness from before. The wheel just stays centered now.
only change from before was setting toe from -.03 to +.05.
Old Jun 29, 2021 | 07:47 PM
pirate4x4_camo
Bravo, glad to see you follow throw and reap the benefits.
Just to be through, what size and psi are you running your tires ?
Old Jun 29, 2021 | 08:14 PM
palacios289
Thanks Pirate.
37x12.50r17. I’m running at 40PSI all around. Do you recommend higher?
Old Jun 29, 2021 | 09:29 PM
pirate4x4_camo
Thanks Pirate.
Lower.
at 35 psi each tire will support 2755 pounds so 2755 x 2 = 5510 pounds
the Excursion's GAWR or Gross Axle Weight Rating is
front 4700
rear 5250
so 35 PSI is your base number that will support your Excursion fully Loaded to it maximum GVWR.
from 35 psi you can adjust up or or down a few psi to balance the handling to suit your preferences
load and inflation tables
https://www.toyotires.com/media/3729...s_20200723.pdf
FWIW I run 40x12.5x17 and at 25 psi they support 2680 each
I typically run 26 front , 24 rear. this combo descreases understeer.
locally my driving is twisty country roads so I try to balance crisp turns with tracking nice and straight at freeway speeds.
dcrahn
Jun 22, 2013 11:32 PM
hhcobra
Jun 3, 2012 09:38 AM
Bigdenis
Nov 1, 2006 06:15 PM
