Sponsored by: Kumho
Alignment specs
Old Oct 30, 2006 | 07:58 AM
Bigdenis's Avatar
Bigdenis
Alignment specs
Hello
Who can give me the alignment specs for a Navigator 2000 (4x4) whith four corner air suspension
Thank
Denis
Old Oct 31, 2006 | 05:11 AM
SRD4X4's Avatar
SRD4X4
Camber; -1 to + 1/4 deg. Caster; 4 to 6 deg. (1/2 deg. more on Rt.side) Toe-in;1/32'' to 7/32'' (7/64'' preferred).
Old Oct 31, 2006 | 11:02 PM
tiredlr's Avatar
tiredlr
This may sound like the obviious, but try to achieve a setting right between min, and max. specs. Also do not vary cross camber by more than 1/2degree,as this can cause a pull
Old Nov 1, 2006 | 03:04 AM
Bigdenis's Avatar
Bigdenis
Thank all,
I will try to set :
Caster : Right 5.50°/ left 5.00°
Camber : -0.5° R and L
Toe : 0.10°R / 0.10°L (0.20° total)
Is it good ?
Old Nov 1, 2006 | 06:15 PM
tiredlr's Avatar
tiredlr
Total Toe Should Be .10. Set @ .05 Per Side
Rich8483
2004 - 2008 F150
Dec 2, 2014 08:13 AM
markd3682
Apr 19, 2014 04:14 PM
jwcnj45
Nov 2, 2004 11:43 AM
Nov 20, 2000 02:41 AM
