Failed Fuel Pump?
Old Aug 14, 2000 | 11:45 AM
RogerW's Avatar
RogerW
Failed Fuel Pump?
I have an 1987 F-150 302EFI. It has been stalling on me over the past week. I went to start it last night, it started, then died. Tried to restart and when I turned the key on I listened for the fuel pump whine several times on each tank and heard nothing. The 1987 has duel tanks, with low pressure pumps in the tanks and a high pressure pump on the frame rail I believe. I was gonna replace the high pressure pump, but I want to be sure it is the problem. Any advise?
Thanks
Roger
Old Aug 14, 2000 | 09:34 PM
PAUL_2's Avatar
PAUL_2
Failed Fuel Pump?
Have you checked the fuel pump relay ? During the no starts , check for power to the relay & the pumps before you spend $$$ on a new pump
Old Aug 14, 2000 | 09:40 PM
RogerW's Avatar
RogerW
Failed Fuel Pump?
No, I have not tried that, because I don't know how to deal with any electrical stuff, I currently have a call in to my personal mechanic for suggestions before spending the $$$. Thanks for some direction though.
Roger
Old Aug 16, 2000 | 03:38 PM
RogerW's Avatar
RogerW
Failed Fuel Pump?
Replaced the Fuel Pump Relay and EEC Power Relay last night, we will see if this corrects my no starts. Thanks for the tip.
Roger
Old Aug 16, 2000 | 04:59 PM
deleontow's Avatar
deleontow
Failed Fuel Pump?
You also may want to check the fuel tank selector valve, this controls the fuel from which tank it comes from, also controls which pump is pumping.
Also check your fuel shut off switch.
Dave
http://a2ztowing.homestead.com/a2ztowing.html
Old Aug 25, 2000 | 02:37 PM
d7cobra's Avatar
d7cobra
Failed Fuel Pump?
I have an 86 F150 that has been experiencing the same problems. It got to the point where I had to listen to the whine of the fuel pump before turning the engine over. I have replaced the High preasure pump many times and still seam to end up with the re-occuring problem. Is there an online schematic of the fuel system and the corresponding electrical parts?
Old Aug 25, 2000 | 11:24 PM
PAUL_2's Avatar
PAUL_2
Failed Fuel Pump?
DrZoom
Jan 19, 2017 12:48 PM
snublifeFFSP
Dec 22, 2015 07:00 PM
1987 F-150
Jun 4, 2013 09:23 AM
cal1320
13
Sep 30, 2004 10:29 AM
blake_2000
Bronco II
16
Aug 29, 2003 06:01 PM
