Correct Coolant??
Old Jun 21, 2021 | 07:57 PM
Matt Pace's Avatar
Matt Pace
Originally Posted by 07 F250 Aggie Mobile
What is the best method to flush? Is there a bottom drain on both systems?
I think there are 2 drains. One looks easy but the other is a pain to get to. Someone else will have much better info that I hope to learn as I need to take this on soon
Old Jun 21, 2021 | 08:16 PM
07 F250 Aggie Mobile's Avatar
So the consensus I am hearing is that my secondary is correct, but I screwed up putting orange in my primary??
My plan now is to drain orange, flush with water and then drain again, then fill with yellow/water mix.
Sorry for sounding repetitive, just want to get this thing back to normal.
THANKS
Old Jun 21, 2021 | 08:50 PM
Matt Pace's Avatar
Matt Pace
THANKS
Orange is fine as long as it's not old. That's what I've gathered. Once it gets old, it's got to go
Old Jun 21, 2021 | 09:23 PM
BillyE's Avatar
BillyE
Originally Posted by 07 F250 Aggie Mobile;[url=tel:19937891
19937891[/url]]What is the best method to flush? Is there a bottom drain on both systems?
If I remember correctly, it took something like 4 cycles of distilled water, draining in between, to get all my orange out. Then drain all, add back x gallons concentrate such that x=1/2 capacity, then top off with distilled. Multiple drains on primary. I used petcock on radiator and oil cooler hose to drain. Secondary I think I just did the one petcock.
I hope I’ve explained myself. It took a little effort but I wanted the orange gone.
Old Jun 21, 2021 | 11:15 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Or...
You can find a shop with an exchange machine...
Old Jun 22, 2021 | 05:05 AM
nomad_archer's Avatar
nomad_archer
Its up to you but ford says your can mix orange/yellow if you need to top off. I recently topped off with my orange with yellow. So far so good.
https://www.fcsdchemicalsandlubrican...patability.pdf
Old Jun 22, 2021 | 01:14 PM
landman873's Avatar
landman873
That's good to know i need about a half gallon to top up from the Tee leaking and didn't want to change it all to yellow for just a half gallon.
Old Jun 22, 2021 | 01:51 PM
GuardDuck's Avatar
GuardDuck
Secondary coolant drain
Primary coolant is on driver's side. Much easier to get to.
Old Jun 22, 2021 | 01:55 PM
ford390gashog's Avatar
ford390gashog
Then top it off with Dexcool if you currently have orange installed. Dexcool and Specialty Orange are the same thing.
camdaddy
Sep 22, 2013 07:52 PM
A/Ox4
Apr 3, 2013 07:14 PM
wildbyon
20
Jun 25, 2006 05:31 PM
Saxon
Aug 6, 2004 11:15 PM
haakeye50
Jan 5, 2003 08:43 AM
