Forscan
Old Jun 20, 2021 | 08:02 PM
sbeamer's Avatar
sbeamer
Question Forscan
Finally got my Forscan set up and working. Found a bunch of codes. Everything was working fine as far as I knew......
PCM codes are PO401, 471, 107, 401C and 471P
SCCM is B137F
HVAC is B11ES
What the ?
BUT!!! I noticed the turbo dial is "almost" all the way to 4. ???? It wasn't like that the last time I drove it. Started it a couple times, revved it a couple times. did not go down, unless I turn the key off. When I turn the key on, it goes right back up there! ????
Old Jun 20, 2021 | 09:05 PM
kper05's Avatar
kper05
The instrument cluster boost gauge? I had to replace the MAP sensor to correct similar boost gauge behavior.
P0401 is generally a clogged EGR cooler core. I didn't always have a CEL for the P0401 until it got worse and became a constant issue. Lightly driving it, you wouldn't know but WOT or towing, you know right away due to the derate.
P0401 – Insufficient EGR Flow
P0471– Exhaust Pressure Sensor "A" Circuit Range/Performance
P0107 - Manifold Absolute Pressure/BARO Sensor Low Input
mutantsquirl
Feb 22, 2023 11:32 PM
'88 E-350
Aug 21, 2019 09:18 PM
bfbiker
Jun 2, 2009 11:36 AM
eco
Jan 27, 2006 09:12 PM
RBWiseman
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Sep 16, 2004 03:03 PM
