Reductant Tank Temperature Sensor Circuit low
Old Jun 18, 2021 | 08:45 PM
mrrop's Avatar
mrrop
Tried looking for my code in other places didn't find the answer. So a new posting sorry if this is posted somewhere else. I got a P205C-001 Code replaced the DEF tank with this
New Diesel Exhaust Fluid Reservoir Heater Kit Replaces for BC3Z5J225KA,BC3Z5J225L,904372,904-372 Fits for 6.7L V8 DEF 2011-2016 Ford F-250,F-350,F-450,F-550 Super Duty Pickup, By LIYYOO.
I went to two diesel shops both wanted over $600.00 to repair. Part was $141 so did it myself, not to hard. After a couple of trips of about 10 miles engine check light reset, vehicle ran and does run fine. Today engine check light came back on same code as before. Any ideas?
Old Jun 19, 2021 | 06:36 AM
senix's Avatar
senix
did you check if yours was under and extended warranty?
Old Jun 19, 2021 | 09:00 AM
mrrop's Avatar
mrrop
Yes, that's the first thing I did when I read the code. Thanks
Old Jun 19, 2021 | 01:24 PM
The Bone's Avatar
The Bone
Mine did that and I had to replace the DEF nozzle. That repair wasn't cheap. had to have the dealer do it because I waited till I was limited to 50 MPH. It tool 3 tries for the light to reset
Old Jun 20, 2021 | 01:28 PM
kper05's Avatar
kper05
Unfortunately I don't remember what or if I had a code for the DEF injector issue. I've had both repairs (DEF heater) as well. Injector was $350. Except mine had dried DEF on the exhaust tips when parked. It also caused it to smoke, for reasons I can't explain, during active regeneration between 600°F - 900°F and smelled horrible. Not saying this is your issue, just going to have to diag more parts of the DEF system.
Old Jun 20, 2021 | 03:06 PM
mrrop's Avatar
mrrop
What Code did you have?
Did you have the same code? I have P205C-001. Everything I checked says it should be the DEF heater. Some people believe it could be the DEF pump. Puzzle is my check engine light went out after changing DEF heater. Then came back on again after a several days. The truck still doesn't have any speed restrictions.
Old Jun 20, 2021 | 03:07 PM
mrrop's Avatar
mrrop
Thanks for all the input.
Old Jun 20, 2021 | 05:12 PM
kper05's Avatar
kper05
The DTC does seem to be specifically related to the tank. Attached some documentation if you haven't already looked through it, page 8 is the brief section on P205C. What is your DEF level?
File Type: pdf
Old Jun 21, 2021 | 06:44 AM
The Bone's Avatar
The Bone
When I fixed mine the light went off by itself. Oh happy day then it came on again. I just took it in when the speed limit came on.
azpat
6.7L Power Stroke Diesel
Jul 12, 2022 08:18 PM
azchris
24
Sep 6, 2021 01:09 PM
gstamand0001
Nov 5, 2020 06:56 PM
Mainedieselman
Feb 27, 2019 07:19 AM
kylant
Apr 21, 2017 10:24 PM
