COP plug replacement
Old Jun 20, 2021 | 10:41 AM
jayro88's Avatar
jayro88
Hi All,
Given that I didn’t know the maintenance history on my ‘01 v10 I went ahead and replaced all the plugs and COPs. While doing so I noticed that all the clips on the COP connectors are broken/missing. Some of the plugs are very loose and slide off and on super easy. I think this could explain the random misfire I get sometimes. The code I pulled pointed to a COP issue.
I see that there are replacing plugs I can buy, but it looks like it would be a real pain to do them. Anyone done this before? If so, was it a pain and what did you find was the best process?
Also, any other ways people have solved this issue? There doesn’t appear to be a good way to zip tie them securely.
thanks
Old Jun 20, 2021 | 12:41 PM
Dweber85rc's Avatar
Dweber85rc
The best repair is to replace the connectors. Its just a simple splice.
Old Jun 20, 2021 | 01:48 PM
jayro88's Avatar
jayro88
Its not so much the act of splicing it that is difficult. It is more trying to get enough access to the wires for the rear COPs in order to splice them.
I did see an option where you removed the pins from the old plug and put them in the new one. Not sure if this would be easier or not.
Old Jun 20, 2021 | 03:00 PM
Dweber85rc's Avatar
Dweber85rc
There is a lot more room if you remove the throttle body and air intake assembly
Old Jun 20, 2021 | 04:00 PM
jayro88's Avatar
jayro88
Thanks. I pulled the air intake tube when I did the COPs and plugs on the drivers side.
I ordered replacement connectors. Guess I will pull the throttle body to fix those.
Old Jun 21, 2021 | 08:31 AM
WE3ZS's Avatar
WE3ZS
Sounds like a great opportunity to do a good deep cleaning of the throttle body and accessible areas of the intake while you are there!
FFEric
2004 - 2008 F150
26
Feb 20, 2022 07:56 AM
Keith0
2004 - 2008 F150
Jul 4, 2020 01:31 PM
Danny Ratliff
Modular V10 (6.8l)
Feb 27, 2016 05:08 PM
andrewzx92000
Modular V10 (6.8l)
Feb 26, 2007 07:39 PM
VIKING24
May 14, 2005 10:08 PM
