2020 SD DTE Towing/Normal
Old Jun 19, 2021 | 03:15 PM
Robert Simpson's Avatar
Robert Simpson
Trailering
Unable to find a previous thread about this. I cannot seem to locate the option to change the DTE calculation on my 2020 F450. Anyone know if it’s an automatic change when selecting Tow/Haul mode? My 2017 F350 has it and my buddy’s 2016 F350 has it. Anyone else have this issue also?
Old Jun 19, 2021 | 05:09 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
DTE is simply calculated by the MPG average multiplied by the remaining fuel.
The calculation automatically varies as those numbers change, up and down.
Old Jun 19, 2021 | 07:14 PM
senix's Avatar
senix
no option that I can recall. The automatic calulations as you drive seem to be better.
Old Jun 19, 2021 | 10:24 PM
KU4OJ's Avatar
KU4OJ
Search for engineering test mode.
When in engineering test mode you can more closely calibrate the trucks overall MPG estimate to match your hand calculated MPG. I think that's what the OP is looking for.
As stated above the truck knows it's real time MPG as shown on the cluster and uses that figure to calculate distance to empty, whether towing or not.
Old Jun 19, 2021 | 10:45 PM
KU4OJ's Avatar
KU4OJ
Try this:
https://www.ford-trucks.com/forums/1...as-factor.html
Search for engineering test mode will yield more information. This allows you to calibrate the trucks MPG readings to more closely match hand calculated numbers. As stated above the truck uses the real time MPG and fuel remaining to continuously update distance to empty.
Old Jun 19, 2021 | 10:47 PM
smikesF350's Avatar
smikesF350
When in the engineering test mode, you can adjust the DTE Default Bias to your individual truck so that the the Displayed DTE is extremely accurate.
Sf jakey
Oct 29, 2017 11:37 PM
lb27312
Aug 29, 2014 02:12 PM
Bowie
All Things Towing
Apr 15, 2011 12:34 PM
mrfoyds
Colorado Chapter
Mar 10, 2008 09:55 PM
cwsnake
Dec 16, 2006 06:46 PM
