Engineering Test mode: AFE bias factor?
Old Dec 8, 2017 | 07:26 PM
railrode1's Avatar
railrode1
It's an adjustable parameter. Any one know what this does?
Old Dec 8, 2017 | 08:16 PM
EKUgrad's Avatar
EKUgrad
I may be mistaken, but I believe that has something to do with correcting your MPG and fuel usage measuring.
Old Jul 17, 2018 | 10:45 PM
agmbg's Avatar
agmbg
Yes. This is exactly what it is. Thanks for the posting. It was the little push I needed to correct MPG Display.
Old Jul 17, 2018 | 10:53 PM
prometheus1351's Avatar
prometheus1351
How do you get to this screen? I'd love to get my mpg reading more accurate. Been off by 1.5-2 mpg each time I check!
Old Jul 17, 2018 | 11:36 PM
agmbg's Avatar
agmbg
Go to “Engineering test menu”. Find “AFE Bias”. Replace 1000 Numberwith the Number from the Formula: : Calc MPG / Display MPG x1000=nnnn
For XLT 4.2 inch Display:
Engine off. Press and hold OK Button on the left side of the steering Wheel. Turn the ignition on Accessory mode only. Do not turn The Engine on. Hold for about 5 sec until "Engineering Test Mode" appears. Turn the Engine on and go through the menu pressing and releasing OK Button. When "AFE Bias 1000" appears press and release Down. Using Left and Right change 1000 to the Number You calculated. Press OK. Actually the steps how to correct the Numbers appears on the screen once You reach AFE Bias. To leave Engineering Mode after You are done just turn the engine off.
For Lariat and up 8 inch Display:
Engine off. Press and hold OK Button on the left side of the steering Wheel. Press push start Button only (Not Brake Pedal) to turn to Accessory Mode. Once Message “Accessory Mode” appears press the Brake Pedal and turn the Engine on. Engineering Test Mode appears instantly. Release OK Button immediately. Then the same Procedure like XLT.
If You are not successful first time try again. It should work and is not going to hurt anything.
I did it on my 2018 Lariat 502A EB. It could be little different on older trucks but similar enough to figure it out.
Old Jul 18, 2018 | 09:08 AM
prometheus1351
Thanks - I'll give it a shot next time I fill up!
Old Jul 18, 2018 | 09:51 AM
wicked 2018's Avatar
wicked 2018
Thank you - be great to fix this in my truck
Old Jul 18, 2018 | 10:46 PM
agmbg's Avatar
agmbg
Just suggestion: It takes I would say 5 to 10 fill ups to get real close results after adjusting. Go to the same pump, do not top up after the click, or just to the next Dollar, empty the tank to the reserve before next fill up...
One word: Try to keep the same conditions every time and get consistent results. Use the result, which is on the middle to adjust the display. Using this I was successful to get +-2% difference, which is enough. The manufacturers are right about variables. In this case the variables are minimized within +-2%. There is no point to adjust AFE every fill up at different conditions.
Old Jul 19, 2018 | 07:05 AM
BillyE's Avatar
BillyE
Never heard of this. Cool, thanks.
Old Jul 19, 2018 | 07:58 AM
ymsmiley's Avatar
ymsmiley
Nice find, thanks. The more you know...
shortride
2015 - 2020 F150
28
Mar 5, 2018 05:23 PM
snakedoc
Mar 2, 2010 10:37 AM
dynamis5
2004 - 2008 F150
Apr 22, 2007 05:08 PM
Geaux-Fish
6.4L Power Stroke Diesel
Apr 14, 2007 02:53 PM
